Question about Whirlpool Washing Machines
F22 code door wont' open - Whirlpool Washing Machines
We had called Sears for an appontment, and the repairman did exactly what your technician had shown as the way to open the door - fortunately, he found that the wire connection to the release handle had come loose, so he had to get inside and reconnect it. Thank you.
Carl
Posted on Jul 22, 2008
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
Jun 28, 2012 | Washing Machines
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting F22 I removed lower front , found door release, opened door I cleaned catch, removed and checked impeller Checked electric connections under the hood Still get F22 code
You likely have a faulty door lock assembly, which is what this fault code is telling you. Most often caused by a faulty switch within the lock assembly itself, you will need to replace the entire assembly. The part is available HERE .
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer door is locked and won't open. Error code
DOOR LOCK ERROR
After 6 failed attempts to lock the door.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool WFW9200SQA12. F22 light
"F22" is a Door Lock error code. This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem, however, is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, opne the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door lacth the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistant error is a failed door lacth. If all these preliminary checks are unsuccessful, replace the door latch. The next link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
NOTE: "Fdl" is the same as an "F22" error code. This error code appears on older models.
I hope you find this information helpful. If you have questions please let me know.
Apr 12, 2009 | Whirlpool Washing Machines
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
