Question about Asko Dishwashers
Wiring diagram for ASKO 1635 dishwasher - Asko Dishwashers
2 Suggested Answers
terryskelly
  • 4581 Answers
SOURCE: is there a wiring diagram available for an ASKO model 1895 Dishwasher? Is how can I obtain one?
https://www.manualslib.com/manual/396362/Asko-1895.html
Free online user manual with phone number and mailing address for Asko.
For warranty service, contact the dealer from whom you purchased the unit or an authorized ASKO service outlet.
Service will be provided during normal business hours. Should you have a service problem that can not be resolved
locally write:
ASKO USA, Inc.
P.O. Box 851805
Richardson, Texas 75085-1805
Advisory Center at 972-238-0794
Posted on May 27, 2018
Need wireing diagram for ASKO 1385 SS Dishwasher
My best guess is this; the white and brown are hot(brown) and neutral (white), so they connect to the 2 posts that are parallel to one another. The yellow-green is ground - that connects to the center terminal.
Apr 10, 2014 | Asko 1385 Dishwasher
I am installing a new pump on my asko dishwasher pump but not sure which wire goes where
there should only be two or three wires main wires brown & blue or red & black. green or green with yellow stripes is earth wire main wires connect to pump motor earth connects to earth point hope this helps
Nov 14, 2009 | Asko 1385 Dishwasher
New Asko Dishwasher. Both the appliance store
Make certain the door switch is making contact and the switch is good. Open the front panel and trace all the wires,especially where they go from the door to the underside of the DW. Look for a broken or pinched wire.
Jul 06, 2009 | Asko 24 in. D3250 Built-in Dishwasher
New install; where to hook up old wiring/plug to ASKO
There should be an installers/repair guide folded up behind the front panel. Check for that as it will show a wireing diagram. I won't be able to get any info until Jan 2. Let me know what you find.
Jan 01, 2009 | Asko D1976 Built-in Dishwasher
Asko Dishwasher Model D1716B Does not fill
Have an Asko 1325 that experienced similar scenario. Removed the unit from the kitchen to the outside to do a thorough exploration. After all a dead machine is a good one to learn on. With the unit electrically disconnected, I explored within the lower guts of the machine. Found some foreign plastic debris within the turbine. Then wigled and removed each electrical connector and reconnected back. There may be corrosion within the contacts. After this procedure I test ran the machine on the outside and it worked.
BTW a common defect with the Asko is the electrical wiring leading up the main door panel, from below the machine. The wires are typically too short and the metal edges of the unit are razor sharp. You guessed it, wires become cut and cause an electrical short at best, or a fire at worst. See the photo for proof by practice. This is why an Asko can be a fiasco. b84ee89.jpg8bbfcfc.jpg
Oct 08, 2008 | Asko 24 in. D3450 Dishwasher
Asko D1706
I live in Australia, My one had the same problem, I found them in e-Bay.
Jul 06, 2008 | Asko D1706 Built-in Dishwasher
Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Jun 30, 2008 | Asko D1716 Built-in Dishwasher
1502 NO POWER TO PANEL
The wiring diagram is INSIDE the metal casing behind the lower kick panel. It is a paper schematic that details the wiring of the dishwasher. Mine was pretty water logged and crusty. Just unscrew the kick panel. It should be right behind it
BTW: Ours also lost power to the panel last week. It's interesting that the production date of our Asko is from 1988. Exactly 20 years. Asko's warranty is also exactly 20 years. Coincidence? Don't bother trying to replace the board. Asko discontinued it and it is no longer available.
May 18, 2008 | Asko Dishwashers
Control Board bad
most of the time there is a schematic behind the kick plate or the door skin but it wont tell you the value or the resistors.but theres normally another cause for the board to blow.is the rinse aid leaking into the door skin,or wires starting to break in the door.the boards are normally sold complete.I work for asko and find the boards dont normally fail by themselves.hopt this helps.
Mar 22, 2008 | Asko 1595 Dishwasher
Dishwashers Logo
381 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
