Question about HP Pavilion dv6000z Notebook
HP Pavilion, Screen working, but extremely dark!
I'm having problems with my laptop screen. My computer starts up like normal, everything working, screen comes on, and after about 20 seconds a noise starts, the sort of noise your hard-drive makes, it gradually gets louder and louder and about 40 seconds to a minute after start up the screen just goes reallly very dark. It is still working because you can see outlines of stuff on screen if you look very hard and close. But it is so dark it is unsuable. I appreciate any help or suggestions, thank you!
  • 186 Answers
As per your description, I find that the issue is with the LCD Backlight which is also called as LCD Inverter which lights up the LCD to show us the Display on the LCD Display.
If this Backlight is gone bad, you will be barely able to see the Display on the LCD.
Coming to the Noise you had mentioned above can be from the Cooling fans of the Notebook which will be spinning at high speed when the Notebook starts and will reduce gradually after few minutes.
I recommend you to try cleaning the Cooling fan vents using any Vacuum Cleaner or Air Blower.
I recommend you to contact any nearest HP Authorized Service Center and get the LCD Backlight replaced.
Hope this helps....
Posted on Mar 07, 2009
When i turn my hp pavilion dv200 on everything on the motherboard can show that is working but no power can enter the screen and the screen can be dark.
but when u open u see a hp bios in screen and next they dark only the problem there is ah program try to format your computer or repair the operating system.
Aug 09, 2011 | HP Pavilion dv4000 Notebook
I turn on the pavioliion dv4 and there is no screen. i hear it on but see nothing
http://www.ehow.com/how_6162556_change-screen-brightness-hp-laptop.html This is a link to with instructions on how to change the brightness of your computor. It may be on too dark a setting now. Another possibility is that the screen has worn out and needs to be replaced. A third is that the computor itself is not working properly now, although you say you hear it on. If it is not a question of brightness (the setting is too low and now everything looks dark), I would take it to a place which repairs HP's.
May 03, 2010 | HP Pavilion dv4000 Notebook
Screen is dark, can see images in a sunny room.
I see this quite a lot. Sometimes it's a loose connections between the motherboard and the lcd display. Especially if the laptop is 3 or so years old. I'm assuming you did a hard reboot and got the same thing. A lot of time the backlight will give out on olfer laptops and the only thing you can do is replace the lcd display or hook it up to seperate monitor. Two things I can recommend are;
1. Plug the laptop into a crt or lcd external monitor and see if you get the same thing or if you actually get a good image.
2. Press [Function] [F4} and see if switching between exteranl and internal monitors makes a difference.
Apr 30, 2009 | HP Pavilion dv8000t Notebook
Screen is dark
DID YOU TRY EXTERNAL MONITOR TO SEE IF IT IS A SCREEN ISSUE
ROD
Feb 09, 2009 | HP Pavilion zd8000 Notebook
Screen went almost completely dark, can barely see at all.
I had a similar problem with an HP DV2000 notebook computer. Here's the solution for the HP model DV2040TX: Problem identified and FIXED. Not the screen, not the screen power supply. The problem was the micro-switch within the right-hand-side screen hinge. This switch turns off the screen when you close the lid of the notebook - probably to prevent overheating. The switch had failed mechanically (technical term: "fallen to bits"). As a low-cost fix, I have unscrewed the main casing including the screws inside the battery compartment, removed the silver panel covering the speakers, flicked the switch "ON" using a jewellers' screwdriver, and removed the small metal tongue that is operated by a cam on the hinge. Thus, the switch is PERMANENTLY ON. Computer operates normally, shuts down normally using Windows. Just need to be aware not to close the lid without shutting down the computer beforehand. Hope this helps you. All the best, OzKluger
Jan 23, 2009 | HP Pavilion dv2000t Notebook
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion Laptop Screen
Bearing in mind you mention the viability of cost, I'm thinking your laptop is out of warranty. This does sound like a pretty major problem, one which HP need to look at. You can always approach them for a quote first, with a min/max price, before you decide whether to go ahead or not.
May 27, 2008 | HP Pavilion dv8000z Notebook
Dark Screen
the ac adapter needs to be pluged in, try the normal mode..
its hard to fix it from here, if you could get someone to look at it?
Apr 12, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
