Question about Dryers
Flame goes on but it does not stay on only 2 3 min.
  • 958 Answers
Sometimes, if the sensor has sense that it is already hot inside the clothes compartment, it would shut off the flame and then after a while it will turn it back on...observe it longer and watch if it will turn back on after a while...then it is just a normal thing...
i hope i was able to help
tnx..drcool
pls rate me...
Posted on Jul 21, 2008
How do I stop my gas fire blowing out 4 mins after it has been lit
Make sure the tip themocoupler is staying in flame of pilot light and your light is a;ll flame flame if not clean it..
Dec 28, 2014 | Heating & Cooling
Sime boiler pilot light
Sounds like an old boiler. It is not on timer and has to be lit manually. Push in the gas button and hold and push the sprung ingnition button to greate spark. Continue to hold in gas button 1-2 mins and release. The pilot light should then stay on. The flame will have heated the sensor in the combustion chamber and the boiler thinks that there is a flame and will allow the main gas jets to light when demanded . If the flame does not stay on clean the sensor prongs with emery cloth but do wait until they are cooled. You have open up the combustion chamber for access
The 1-2 mins above varies
Apr 07, 2014 | Water Heaters
Flame ignites and stays on for @2-3 mins and then goes out and will not re-light
Sorry to read about your problem, I hope this helps you out.
you may have a defective flame sensor
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Maytag Dryers
I have a natural gas poolheater- Raypak Versa 305. The pilot lights but when I release the button after waiting1 min. the flame goes out. This happens over and over so what should be done?
You, or someone should check the flame sensor. If , as it looks, you have a standing pilot (one that stays on), the flame sensor has to be aware of the pilot or all will go out. Good luck...Lee
Jun 10, 2010 | Raypak BURNER TRAY ASSEMBLY
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
Mar 03, 2017 | Desa International CBN20T Heater
Flame goes out when fan kicks on
If the flame lights all the burners within 2 seconds but does not stay on, you may need to clean the flame rod found at the farthest end of the burner box. It will be located at the end of the box that lights last. It will be a probe that is in the flame of the last burner. If it has carbon on it or scale, take an old tooth brush and scrub it. Check the wire connected to it and follow that wire back to the circuit board and check that connection.
Dec 11, 2009 | Goodman Heating & Cooling
Gas dryer flame won't stay lit
Check for a blocked vent.
Mar 12, 2009 | Amana Dryers
Flame goes out
the most common problem is the flame sensor located just behind the fire chamber, about two inches long in a round rubber boot with two wires. you can get one from mr. heater for about 3 bucks. the wires are a different color but all you have to do is splice them to your old wires. it doesn't matter how you connect them.
Feb 02, 2009 | Reddy Heater-30-55,000 BTU Variable
Furnace pilot problem
check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Jan 10, 2009 | Honeywell Power Humidifier: Furnace...
Dryers Logo
64 people viewed this question
Top Dryers Experts
