Question about Kensington Expert Mouse Trackball
Model 64213 horizontal movement does not work or moves left only
Peel up the lower corners of the serial number sticker on the bottom side of the trackball to expose the two Phillips screws that hold the assembly together. Remove those and take the top off. Lift out the circuit board and be careful not to lose the little idler roller that sits thereon. Unplug the cable and you can then access the rollers with ease. Clean them with alcohol and remove any fuzz or dirt with tweezers, and it all goes back together the way it disassembled and should work fine again. Takes less than ten minutes.
Posted on Nov 08, 2008
Viking 1+ Horizontal movement quit working after needle hit something
it sounds like you knocked the machine out of time & it will have to be taken to a
sewing machine shop to be retimed
Apr 26, 2012 | Sewing Machines
I do not know how to wind up my watch, while a swing to a later no.Please answer me.Model hours a Seiko Kinetic 5M62-0B40.Thank you
This watch operates on a capacitor which is charged by movement. It does not wind, but it has a weight that charges the capacitor by motion.
Take the watch in hand by placing your fingers under the caseback and your thumb on the crystal. Use a horizontal motion (landscape) to move the watch back and forth quickly approximately one foot left and right. You should feel the internal weight move.
Do this for at least five minutes. If the watch does not start to operate (the second hand does not move at one second increments) then either the capacitor must be replaced, or the movement is defective.
You may send the watch directly to Seiko for service, or I would strongly suggest visiting your local Certified Master Horologist for what is usually a free assessment and estimate of the repair.
If you are following the above directions, you have done nothing wrong, but the movement or capacitor needs to be replaced.
If you have just purchased this watch and the instructions do not resolve your situation, I would promptly return it and exchange it, as the model may have been sitting for a while, and have a bad capacitor.
Feb 23, 2011 | Seiko Kinetic watch
Husqvarna YTH2348 hydrostatic transmission slipping
Check your tensioning bracket, when parked and engine off, lower the deck, look underneath from the left hand brake pedal side and work the brake pedal by hand take notice of the bracket with two pulleys mounted on it that move with the brake pedal being pressed and depressed, if you have vertical? up and down movement opposed to horizontal fwd and back movement your bracket mount and or bushing could be worn out.. Mine was, and after replacement it was like the day I bought it new.
Hope you his helps..
Jul 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Kensington 64213 Expert Pro Mouse poor tracking and will not move cursor to the left
Cause:
I found the cause and solution. Dust and debris settle in the up and down roller more so than the side to side roller because of the angle and gravity.
Solution:
You need to take apart the plastic housing and then dismantle the circuit board to get in and remove dust/debris from the up and down roller area. You will need a magnifying glass and small flash light to really inspect the area. I took a sewing needle and carefully removed all the debris on both sides of this roller. I then blew the area clean with my mouth. You should actually use a compressed air spray from an electronics store. After removing all the debris and air spraying it clean then assemble back to normal the circuit board and housing. Bingo! This solved the problem which is not an electronic problem but a mechanical one.
Nov 25, 2009 | Kensington 64213 Expert Mouse Pro
My tv needs to be converged but i can't
the left and right volume buttons are what move the convergence horizontally, so if they dont move you will need to replace the convergence ICs .if you need more info I will need the model number of your JVC
Mar 13, 2009 | JVC Televison & Video
Logitech wireless laser mouse will not move, pointer is stuck mostly on horizontal movement, won't go up or down, struggles to move in any direction really
change the batteries of the mouse if that didnt work.
try to clean the otycan head of mouse.
PLZ do RAte this post.
Dec 17, 2008 | Computers & Internet
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Model 64213 (not a wireless model) Trackball is not working smoothly - already tried cleaning it and still gets "stuck" especially moving left and right. Up and down works well.
This is because the wheels that move with he trackball are getting stuck.
Try cleaning the inside housing.(The part that holds that trackball) Mainly, the tiny wheels that grab the trackball. Normal use can build up a gummy buildup inside that can be easily rubbed off with a cloth. Since the housing is underneath the trackball, there can be a greater potential for lint, crumbs or anything else to get inside as well. Clen in there, empty out any debree and you will find ti moves much smoother.
alternatively, one of the tiny wheels could be damaged and is not rolling properly. Roll each one with your finger to see if you can feal anything rough or if the wheel is rubbing against something.
Jul 28, 2008 | Computers & Internet
Kensington Expert Mouse Trackball Logo
225 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
