Question about Maytag Kitchen Ranges
Oven not heating - Maytag Kitchen Ranges
  • 37 Answers
Gas or electric. For Gas the Igniter is probably faulty. Remove the bottom plate inside the oven and look where the pilot light would normally be. There is a coil of wire that is suppose to get white hot when you turn on the oven. It conrols the gas flow and ignites the gas.
If it is electric check to make sure the heating coil is in one piece. You can also measure the resistance of the coil (with mutimeter). The oven tempature can be contolled by a dial or digitally. If digitally controlled you may have a faulty relay. Be careful moving the oven due to possible gas leaks and for the electric type ovens electic shock can kill. Be careful and good luck.
nssms
Posted on Jul 21, 2008
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
Frigidaire pleb30t9fcc double oven -- top oven heats fine --- bottom oven does not heat up all the way
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
May 14, 2010 | Frigidaire PLEB30T9FC Stainless Steel...
My oven will only heat up to 250 degrees
heatman101
May 12, 2010 | KitchenAid KERC507 Electric Kitchen Range
Oven not properly heating
heatman101
May 06, 2010 | Viking 30" Professional Select Built-in...
We have a GE JKP15 oven that will not heat to temperature (350F) when first turned on. The oven will beep (temp confirmation) and the display will indicate 350F but the oven temp will only be at 220F...
heatman101
Dec 26, 2009 | GE JKP15 Electric Single Oven
Top oven works fine bottom oven won't heat
heatman101
Dec 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Upper oven will not heat above 250 , lower oven works fine
heatman101
Jul 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
The oven stopped heating but the convection oven function works
heatman101
Jun 23, 2009 | GE Profile JTP18 Electric Single Oven
OVEN TURNS ON BUT WONT HEAT UP.
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
GE Double Oven JKP45BA, lower oven wont heat
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Kitchen Ranges Logo
248 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
