Question about Canon S520 InkJet Photo Printer
Canon s520 printer
My printer stopped printing black. I have a full cartridge, I tried cleaning the head, deep cleaning the head, aligning. Still have a very faint dots where letters should be. Is this something I can fix or do I take it for repair. Thanks, Mike
  • 1 more comment
  • YoYarrow Aug 13, 2008
    change paper settings from what to what?
  • bharath18kc Sep 04, 2008
    i replaced new cartridge ,after that its taking the paper to prinrt but its not at all printing in any color,,,
  • fstace Sep 17, 2008
    I have exactly the same issue with mine. Colors print fine - so its not a paper thickness issue? Did we get a fix for the original problem posed in this forum?
Try changing your type of paper setting.
Posted on Aug 06, 2008
Replaced black, would not print black, deep clean times two and still the same problem. What can I do?
Hi, the print head needs to be removed and washed with warm water, Please check the manual for print head removal and re-installation. Also print head alignment must be done on re-installation. The process sounds complicating but is quite simple. Do as if you are replacing a ink cartridge. When the print head is at centre in this process and stops.Switch power off on printer.Remove the cartridges, then remove the print head, wash in warm water carefully, do not use any brush or do hard rubbing, dab dry on paper towel. Replace print head into printer, then cartridges, then switch power on. Do print head alignment, clean print head once and print test pattern. Hope this helps as it has worked for me and is still working. All the best.
Mar 10, 2015 | Canon PIXMA MG5420 Inkjet Photo All-in-One
My printer will no longer print in black s520
if it is a new black ink cartridge and the printer still wont print black start by:
A: Simply making sure the settings are ok. To do this, go to file>print. When the printer box shows up. click properties.
From there, you will be able to see color settings. (ex. black, grayscale, full color.) Try switching to black or "use black cartridge only.
B. If "a" does not work for you, the print head which hold the ink cartridge is clogged or no longer working. Through the cannon window on the printer, try running a print head cleaning or any maintenance program.
If there's still no black, the print head has seen better days and needs replacing. Most of the time it is more effective to get a new printer.
May 22, 2011 | Canon Office Equipment & Supplies
I have replaced the black ink in my canon s520 but printer will not print out black
Please check the seating of black ink cartridge. It may not have been placed correctly. Please replace it and then carry out the print head alignment.
Aug 04, 2010 | Canon S520 InkJet Printer
Canon S520 Printer won't print black!
Remove Black cartridge,
make sure its not dry, if that's ok make sure that the small air vent is not blocked (hard to find sometimes)
Dec 30, 2017 | Canon S520 InkJet Printer
Canon MP530 All in One Printer won't print black
Try deep cleaning the black cartridge in the Maintenance section of the printers properties. Print head might be clogged cli-8m
Sep 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP760 black ink dull and has stripes
Take the cartridges out and also the printhead and set the nozzle of the printhead on a 5-sheet pile of kitchen paper that was make wet in the middle with some lukewarm demineralized water ( water for an iron )there is not much necessary if there are clogged nozzles deep inside the printhead buy cartridge flush different methode for printers to find
How To EASILY Unclog Ink Jet Print Heads
Aug 26, 2017 | Canon PIXMA MP760 All-In-One InkJet...
Every 4th or 5th line does not print
try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Dec 19, 2007 | Canon i850 InkJet Photo Printer
Black jet not printing
re-install the driver and see. bye
Sep 23, 2006 | Canon S520 InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
111 people viewed this question
old marine
old marine
