Question about Kitchen Appliances - Others
Sears table saw
I have an older table saw that i bought for $25.00 at a garage sale. the problem is that it is 240 volt/single phase, and i do not have , nor can i run 240 to my garage ( not enough free space in my breaker box) . it is a craftsman saw.
can it ( the motor ) be converted from 240 volt to 110 volt ,and if not, where might i find a 110 vol;t motor to fit it?
  • gkos Dec 26, 2008
    my problem is similar. the saw is almost 50 years old and my motor burnt out. i am now looking for a replacement motor and i am trying to find a cheap way out. if you find a cheap source of saw motors, let me know...........thanx
  • Mike Durland
    Mike Durland May 11, 2010
    i am sorry but i don't have experience with table saws, i am sure that if you were able to change it to 110v it would have 220/110 on the motor somewhere.
Buy a new 110v motor.Tho the current will higher and get a motor with the horse power and same motor base # so that the mounting holes and the shaft size and position match the old motor.
Posted on Oct 03, 2008
Why not install a few mini-breakers in the panel to give you more space. You probably won't be using this saw 24/7, right?
Posted on Sep 15, 2008
DO YOU WANT TO SELL IT ?
MY EMAIL JCD339@AOL.COM
Posted on Jul 24, 2008
Jet table saw 3hp, low torque! New saw, correct electrical hook up, but not much power at the blade, so yes it runs but no torque! mag switch in test position, does it need to be in auto???
I am not sure what model you have but they have this saw in two models one is 230 volt only the other is 230/460 volt.
But that is not a 220 volt circuit. 220 volt is single phase where the 230/460 is a 3 phase circuit.
Look on your motor and see what the power requirement is.
if you have a different machine then the one I am looking at I would switch over to the auto function.
May 10, 2017 | Jet Saws
I need a motor RM870
go e-bay and type in electric motors in the search section
what you will be looking for is an electric motor with the following properties
240 volts
rpms the same as your motor or within 150 rpms
single phase
60 cycles
shaft size the same as yours and the foot mount measurements for the 4 bolts and distance from the face to the drive puller so that it aligns with the rest of the saw
Jun 14, 2016 | Saws
Www eemaxinc com support
My limited research indicates this heater is designed for USA electrical systems. That would mean single phase, 240/208 volts, 60 Hz. The drawings I reviewed shows a 2 pole, 240 volt breaker feeding each heating circuit. That means no "neutral wire" goes to the heater and therefore no 120 volts is needed. This is good. Kenya's system is single phase, 240 volts, 50 Hz. The heater should work reasonably well on the African system. Connect the power just like you would in the US.
Jan 17, 2014 | Water Heaters
Motor burned
Single phase 220 volts actually uses two 110 phases to deliver 220 volts. So the failure was caused by something else. The motor winding insulation may have been cracked or previously damaged by high current. The solution is to replace the motor or have it refurbished (not cheap).
Dec 25, 2013 | Saws
Unisaw single phase 3hp magnetic starter keeps blowing actuator coil
Should check the voltage on the coil if its a 220 volt saw could have a 120 volt coil
Nov 07, 2013 | Delta NHD STARTER SWITCH ASSY. FOR UNISAW...
Single phase motor 220 convert to110v; do you have switch wire inside the motor
There should be a label showing the change, one wire gets switched over to a different screw, all motors are different, but all basically the same, some will not switch. It would be just as easy to run a new line to your motor and it will be right, single circuit, 220 volt,?amp, no worries., Your motor as is will not run in 110 volt mode at all. Hope this helps.
Feb 26, 2012 | Delta Table Saw Tool Base 50279 Band Saw...
My table saw will not start. the power source is good.
If the motor is using a single phase supply there will be a capacitor which could have reduced in value- open.
If so try and use a capacitor in parallel to see if the motor works-- in this case the motor might hum and get heated up.
Mar 11, 2011 | Delta 36 982 10 Inch Left Tilt 1 1/2...
My Elektra beckum TKHS 315 EP Table saw keeps blowing fuses. When I turn it on it tries to go backwards then blows the fuse. The blade is securely fixed and spins freely. There are no obstructions. It is...
Hi I have the same problem - I think it may be the capacitor by the motor which has failed - I have just ordered a spare which I hope will fix the problem. Check the capacitor for any signs of damage ie. explosion!!
Jan 16, 2010 | Saws
Missing parts for guard assembly craftsman table saw 133.299315
You will have to start searching craigslist and amazon, estate sales, garage sales etc.
Nov 24, 2008 | Craftsman Saws
Kitchen Appliances - Others Logo
132 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
