Question about HP PSC 2210 All-In-One InkJet Printer
Scanner is grinding
How to I get in there to clean it?
  • sweet_t_jewe Jul 21, 2008
    how do I get into the scanner area to clean the mirrors?
  • 61 Answers
Open the printer clean mirror in inner side , open ccd and clean mirror properly by the tishu paper please not you nolon cloth and if the problem will also coming the replace scanner ccd your problem will be surely solved
Posted on Jul 24, 2008
Scanner grinds when powers on
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Dec 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
The scanner works but makes a grinding noise that is getting worse
Normally Canon scanners work well for long time, Change the pickup rollers for every 250,000 pages and check other rollers for every 500,000 pages. In case you have been scanning documents with quite a good amount of dust, you may need to check at an earlier interval. Replace any worn out roller. Check if the small bearings at the end of each roller is perfect. Clean thoroughly all the rollers, dont use solvents. S. Mohan, Chenna, India
Sep 10, 2010 | Canon DR 3060 Path-Through Scanner
My CanoScan LIDE 90 will start scanning, then stop, while making a sort of grinding sound. Over and over the same thing. done it since new just never took it back!!!!!!
Remove the glass using a knife to remove the the gray plastic on both sides and in front. They are held in place with double-sided tape. Clean the inside of the glass with rubbing alcohol. Also clean the insides of the center track and the silicon bumps on both sides of the scanning wand. put a tiny amount of spray silicon on a Q-tip and run it up and down the insides of that center track. Use the Q-tip again to wipe the silicon bumps. put it back together and there you go!
Feb 25, 2010 | Canon CanoScan LiDE 90 Flatbed Scanner
Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Apr 15, 2009 | Epson Perfection V100 Flatbed Scanner
Grinding noise
There is usually a slide type button somewhere around the outside of the scanner and it usually has a lock & unlock sybol on it. You may want to make sure that it is slid totally in the unlock position because it could be getting caught inside once in a while if the button is say half way between lock and unlock... Hope this helps...
Sep 24, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Scanner making grinding noise
Please open and apply oil on roller rod as some rust have accumulated on it prohibiting it move.
Jan 01, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Brother MFC-425CN
AF after cleaning cycles??????????????????????????
AF means that the scanner flatcable is not connected to the main pcb (When powering up you should hear a grinding sound from the scanner area). Open the scanner cover as for changing the ink carts. Open the small cover (looks like a " L ") and connect the white flat cable simply by pushing it into the main pcb.
Oct 25, 2007 | Brother MFC-425CN Multi-Function Center...
Noise
this is a normal thing with scanners i have read reviews about different scanners where the scaners were good prices the only downfall was the noise
Jul 03, 2007 | Panasonic KV S2026C Path-Through Scanner
HP PSC 2210 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
