Maytag MAV7600 Top Load Washer Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WATER LEAKING FROM TOP WHEN START SPINNING,MY WASHER IS MAV 7600AWW,I CHANGED THE SEAL AND STIL LEAKING
Paul Bade
Level 3:
  • Maytag Master 1,818 Answers
  • Posted on Feb 04, 2011
Paul Bade
Maytag Master
Level 3:
Answers
1818
Questions
Helped
574895
Points
5816
Does this happen on any water level setting, or just on full load? If the machine is overfilling, the centrifugal force at the start of the spin cycle will throw the water up the sides high enough to overflow the top of the tub.
If the machine is overfilling just a little as I suggest, then the water level switch may be out of calibration or the water level hose may be partially clogged at the tub end. A quick fix in the latter case would be to disconnect the hose from the level switch and blow compressed air through it - it's a lot easier to get into the control panel than the side of the tub. A leaky hose would have a similar effect.
The washer was leaking so I changed the tub seal. However it is still leaking water on the shaft below the motor
Must be the tub seal is still leaking, you may not have got it seated real good and you need to let it dry for 24 hours before using
Kenmore 417 97962705 Leaking below tub from transmission gasket
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front.
Making noise when spinning
HI there.This sounds like the centre bearing & seal are worn causing noise & water leak.It's normally called a Hub & Seal Kit.It is quite an involved job & without the right tools it would probably cost somewhere around $300 upwards to have repaired.Very good quality machine & worth while repairing.Try to avoid useing the machine until repaired as you could cause electrical short due to water leaking.
2helpful
Leaking from the bottom of the washer.
it sounds as if the main tub ring is bad you need to pull your agitator out and check the two blots that hold the tub to the shaft and make sure they have not become loose or broken causing the inner tub to drop on the shaft and tear the tub seal.
2helpful
WATER LEAKING FROM BOTTOM OF WASHER
Check the seal between the top plastic cap and the outer tub. There are 6-8 clips that secure the cap to the tub. My washer would leak water when full and start spinning. I found the seal split in two.
Thank you for contacting www.Fixya.com
1helpful
Noise, leaks water
if it is doing this then sound like the bearing seal has gone and is leaking water into the bearings is the water brown or a grey in colour
1helpful
Water built up in Maytag Washer Model MAV-17
I would check the water valves or the water lines. If the water valve is leaking, the water could be running out and following down the cabinet then in to the tub, or the water valve water line that leads right in to the tub there for leaving a water build up.
Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
