Question about Gateway FPD2275W LCD Monitor
Mag Innovison LT917S LCD Monitor
Initally no power light or video. Replaced Power supply electrolytic caps. No change, further troubleshooting revealed 2 of 4 FETS (AO4606) shorted on the inverter section. Replaced shorted FETS. Power light now solid green but video is incorrect. The BIT3193 VDD pin is used by the video control board as a blanking signal. The video is present for about 1 second and then disapears. Each time the screen is unblanked video will appear for one second. It appears the BIT3193 is shutting down but I can't figure which signal is bad, I believe pin 8 and 9 of BIT3193 should be the same. The voltage on pin 8 is about 6 volts and on pin 9 1.3 volts, Pin 9 feeds pin 15 (ISEN) which if I'm right will shut down the BIT3193 until the chip is reset by the removal and application of power (VDD) from the Video control board. I can't find schmetics to help. I used a comparison method to test the transistors on the inverter board which showed they were the same (good). I have run out of Ideas. Help please! Where can I get schmatics? The BIT3193 may have a bad pin 9 or does ISEN pin 15 pull the voltage down? I'm lost now.
Thanks,
Duane
  • 37 Answers
After looking at the description of the pin outs on the BIT3193 and following signals to/from that chip I discovered I had burned up one of the FETS that I had installed. With the FETS replaced for the second time the monitor works fine now. HEY!!
Posted on Aug 21, 2008
Repair Sony nsx-40gt1 tv, no picture, 2 red blinking lights where normally green. Is the power supply board bad, t-con bad or main board bad. Who sells repair manual?
Hello Eric,
shopjimmy has the circuit boards and gives live support..
Check out the URL below.
Also consider getting an anti-static wrist band... so you don't destroy good semi-conductors with tiny static sparks.
Further information on that is under "ESD"
(Electro-static Discharge)
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2016 | Sony NSX40GT1 40 Inch Internet TV powered...
The unit will not show a picture. the power lamp flashes and all buttons are unresponsive, including the power button... I have unplugged all cables, including the power cable, then allowed the unit to...
You may have dying power supply problem due to bad DC filter caps, which is is very common problem in ALL LCD monitors. You need to open it up and do some in-depth troubleshooting.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Samsung SyncMaster 2220WM 22" LCD Monitor
ViewSonic VE170b 17" LCD Monitor Faulty power
You need to check the fuses on the backlight inverter board, also the logic board may be damaged by the AC voltage.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Basic LCD monitor troubleshooting guide:
Dec 02, 2010 | ViewSonic VE170b 17" LCD Monitor
Mag Innovation LT916s 900p LCD with a Horizontal twitch
That is capacitors problem, I would change all the caps in the 5v and 12v power supply section, you can have bad caps with high ESR. Also look at the caps on the logic board. I use hair dryer for troubleshooting to locate bad caps.
http://s807.photobucket.com/home/budm/allalbums
Apr 15, 2010 | Mag Innovision 19" LCD Flat-Panel Monitor...
LT1919WDB FLAKEY PICTURE
When the LCD Controller cable is diconnected from the LCD panel, the screen should be completely white due to the Liquid crystals do not have the bias voltage to block the backlight from coming through the front of the screen. Unless you have intermittent shorts circuits on the LCD controller board (part of the LCD panel) that load down the 5vdc (logic power supply). The capacitors on all the board look OK? See the pictures of bad caps in the monitors here and post back what you see on your boards so we can go further with troubleshooting.
http://www.badcaps.net
Apr 09, 2010 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor flashes on but with 1-3 seconds it goes to balck screen. I've replaced the electrolytic caps in the power supply, but it didn't help
Try different video and/or power cables, but most likely this is dead. Sorry!
If it's still under warranty, (or the computer it came with is), call Gateway support.
Mar 10, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
Mag Innovision LT576S monitor goes blank after 2 seconds
I would think that the monitor is the issue, especialy that in safe mode it still does not function properly!
The fault with the monitor may be in the scan amplifier circuits, and or the power supply.
When I used to service these, I found many times that there were defective electrolytic capacitors in the scan amplifier sections and the power supply that gave problems.
This type of repair is time consuming, and when out of warranty it may not be worth the cost.
I would be seriously considering an LCD monitor.
Jerry G.
May 19, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
220 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
