Question about RCA 20F420T 20" TV
TV Turns Itself On & OFF with Notepad showing each time
When I plug the set in it will continuously turn itself on & off and every few cycles it will stop cyclin & will show the picture but the notepad is on when it does this & when pushing the notepad to turn it off it will sometimes show only the picture & sometimes it just starts cycling again on & off.
This TV wasn't even 8 months old when it started doing this but Wal-Mart wouldn't honor the return policy on it so I'm stuck now. It wasn't an expensive TV, but it's the principal of the problem and Wal-Mart Not Honoring their Products!!!
I do computer and satellite receiver repair & I feel that this is a Programming problem with the Flash/Eprom chip or somthing of that nature as the capacitors & Circuit board look to be in good shape.
Same problem this TV. Tried troubleshooting by remote control, front panel bottoms, etc. It keeps on turning off...
Hope someone can help...
Thanks.
Posted on Aug 16, 2008
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
TV turns itself off after being on a few seconds, ...
Three time blink means tv got problem in convergence output circuit, replace convergence output ICs to solve the issue.
Thanks.
May 21, 2010 | Panasonic PT-53WX54 53" Rear Projection...
TV turns off by itself
check to see if the sleep timer is somhow been turned on and set
Mar 17, 2009 | Mitsubishi Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Motor never turns itself off
If by motor you mean the compressor itself then no, it should not run all the time. The compressor should run until the thermostat senses the temp. is at where you set it then turns off the compressor. A couple of possible things... if the unit has a leak in the refrigerant then it may run almost continuously since it can barely reach the cold setting you have selected. Or the temp. sensor thermostat may be bad and the unit doesn't know to turn off. There is also a defrost cycle that happens about every 12 hours for a few minutes (depending on make/model on how it works) but that should also turn off the compressor and fans until the defrost cycle is completed. Basically it should turn off when the temp. setpoint is reached or when it's in the defrost cycle.
Jan 14, 2007 | Admiral 26 cu. ft. Side-By-Side...
T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
Sep 12, 2006 | Philips 32RF50S 32" TV
RCA 20F420T 20" TV Logo
62 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
