Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Power jack is loose...
I've got a computer here (HP Pavillion zv5000) from a friend who says the power jack is loose inside the computer. She has to literally put a rock under the power cord after she plugs it in to keep it working. Is this worth opening the laptop and replacing the female end of the power jack or should I just tell them to replace the laptop?
  • 1 more comment
  • Jason Starr Jul 21, 2008
    I haven't opened it yet. I was just feeling out possible solutions first. I check it out though.
    Thanks!
  • HP Help pls Sep 24, 2008
    I have benn having the same problem for almost a year now...I have had to prop up the male portion of the power cord in various angles to keep it in perfect contact with the female end, so as not to shut down abruptly. I would really like some help with this issue.
  • gwhokie81 Apr 11, 2009
    My daughter's HP zv5000 has a problem with the power jack. When you first plug the male connector into the jack, the blue lightening bolt is on for a few seconds, then you have to giggle it around until you find a spot to keep the connection. I cannot afford to replace the computer at this time, but do not want to make a costly repair. Is the problem most likely with the female or male part of the connection?
  • 502 Answers
Unplug the powercord and try to move around the powerjack with a small flatheat screwdriver. If the jack moves around freely or the middle pin has too much slack you most likely have a defective DC-Jack. You can replace it yourself there are guides online that show you how to do this, just use a search engine and they will turn up. The repair takes about 2-3 hours. I work for a company called Laptop Repair NYC and we do this repair frequently.
Posted on May 22, 2009
I had the same problem. Took an hour to take take the thing apart (http://www.hp.com/ctg/Manual/c00212209.pdf), and then sure enough, the 4 pins that connect the power jack to the mother board were loose. I tried to solder them back, but there was some sort of coating that prevented the solder from taking to the mother board pad, so I had to scrape the copper around each pin, then the solder flowed well. Another tip is that there are 3 ribbon cables that connect to small white connectors with a very small brown cap. All you need to do is pry the brown cap on either side of the connector about 1 to .5 mm out and then the flat ribbon slips out. Assembly is simply the reverse. Works great now. It's like new.
Posted on Feb 03, 2009
I had the same problem on my laptop, HP Pavillion zx5000, and found that this is an extremely common issue.
I sent my laptop to an Illinois repair facility: see http://www.powerjackrepair.net/ They fixed it in days(for $125 + cost of one-way shipping to them) and now it works great!
Be sure to follow all their instructions if you choose to use them. I removed my hard disk, which is not too difficult for most people to do, as long as you have a set of small screw drivers. That way their is no privacy issue with sending your pc to strangers.
Another good site I found is: http://powerjackrepair.com/ It's a totally different site from the above. It's for UK folks but seems to have an excellent Diagnostics page.
Posted on Dec 14, 2008
  • 156 Answers
Just replace the female socket of adapter but from a qualified expert in your area.Don't try it by yourself.Because opening a laptop is very annoying and Hes ti also lot hard for a normal guy.So i suggest u to take this laptop to service centwr or to a local expert.
Regards,
Sandeep Singh
Posted on Jul 21, 2008
  • HP Master
  • 2,794 Answers
Depends on if it cracked the motherboard with it. If it did it will have to be replaced as well.
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
How do i get my hp pavilion zv5000 to run on ac power only. it will only run on the battery.
Zv5000 Laptops are plagued with problems related to the jack on the back of the computer. After prolonged use the jack tends to make the solder joint loose. Jacks can also go bad. The solution would be to check if the power comes on momentarily when wiggling the plug in the jack, if the power comes on intermittently then chances are you have a loose solder joint and may need repaired by a qualified tech. Fortunately, for the technically savvy this may be done carefully provided the proper static sensitive precautions are taken, due to the fact the computer must be totally dismantled to get to the jack and properly inspect the solder connections and repair or replace the jack. Silver heat sink compound must also replace the silicone on the processor ( one dab and compress, do not spread compound!) The jack need should it be replaced can be found on Ebay
Aug 05, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion zv5000 - No power with battery in.
the jack is the problem it is not getting enough power to laptop
Nov 02, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
My HP Pavillion zv5000 power problem
Just fixed mine again!
you need to solder 2 wires to the computer connection then chop of end of cable so that you can solder together. Make sure you get them round the right way!
Apr 07, 2009 | HP (350827-001) for Pavilion ZV5000,...
I got an hp pavillion zv5000 dont have power on / bios passw
Sorry to say, but I think you'll need to contact HP support on this. They have a great chat feature that they can help you on.
I just think most people will be hesitant to assist you with bypassing passwords, but I could be wrong!
Hope this helps, anyway.
Mar 28, 2009 | HP Pavilion zv5000 Notebook
What is largest HDD and mem card can I put in HP Pavillion ZV5000
According to the HP website , the biggest hdd that you can put is 80GB and memory is 2 gb.
Check the following link for more
http://tinyurl.com/ch6hn7
Select the mdel number and proceed with part search
Thanks
proton
Mar 12, 2009 | HP Computers & Internet
Hp pavillion zv5000
Most small computer shops can get the internal power connector for laptops. It will cost about 50 bucks.
The connector will have to be soldered onto the motherboard.
G'luck
Nov 11, 2008 | Sony VAIO VGN-FJ270/B Notebook
Laptop
Yes this can be repaired, and I believe this to be a good machine and worth it. The cost for a jack repair is approx $100 at most smaller computer shops. Bestbuy, however, will be a heck of alot more expensive. You should have the jack repaired ASAP. A loose or broken jack can cause an electrical arch which can, in turn, cause severe damage to the machine. Damage that may force you to buy a new laptop.
Jul 26, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
655 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
