Question about Whirlpool Dryers
We have a 6-year old Whirlpool Senseon "Gold" dryer that really never worked very well. It heats clothing too much when using the Low setting. Yesterday we had a load of clothes in the dryer set at Low and the dryer just kept running well after it should have shut off. We had just returned from a vacation so we were pre-occupied with other tasks. When we went to check the dryer, the laundry room was like a sauna! The window in the room was all fooged up and water vapor was running down it and the dryer was so hot we could barely touch it! What is wrong? This has happened before, always when using the LOW setting.
  • carole_fj Jul 22, 2008
    Thanks Oldfixer! Joe did check the vent hose and found that it was not securely attached to the back of the dryer. It seems to be working OK now!
    Genius:
  • 1,028 Answers
Ck for torn vent tub be sure vent hose is not mashed and has GOOD air flow to outside
Posted on Jul 22, 2008
I have a Whirlpool Gold senseon Model number GeX9868Jq1 I can feel the heat inside to Dromm but when I push start it just clicks It's a electric dryer
Unfortunately, it sounds like the motor, since you aren't hearing it run. Motor turns the drum by way of a belt.If motor is running, but drum not turning, it would be the belt... I would also say door switch, but then the heating element wouldnt be heating up. Slight chance it could be the control, but I doubt it. DW
May 12, 2014 | Dryers
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
Oct 14, 2012 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Mar 16, 2010 | Whirlpool Dryers
Dryer has heat..but very low temp , takes forever
Make sure that your vent pipe is completely clear of excess lent. It will not dry properly if the venting is not running freely. If the unit is cleared of lent, inside and out, the only other possibility is the thermostat is not reading correctly.
Apr 11, 2009 | Dryers
My electric whirlpool senseon dryer won't heat
lint screen on top///repl/thermal fuse in rear of dryer, if screen inside dryer remove front bottom panel, next remove blower housing on top off is the other thermal fuse ,, gurantee fix
Nov 29, 2008 | Dryers
Clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Nov 19, 2008 | Kenmore 63942 Dryer
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
162 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
