Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi wt-46809 46in wont power on
I have talked and researched what could be the problem and most replies are that the convergence ic's need to be replaced. I just wanted to know could it also be a power supply problem? I had a service man come and look at it and I feel he was taking advantage of me. I was quoted 1800.00 for the convergence ic's a new power board and 3 lenses. I did the self diagnostic test and the series of flashes are 2.2. When I turn the tv on the green light lights up and then I hear a click and then it shuts off. I have noticed that the color seems to separate green and red but after a few seconds it blend together and seems to be fine until it just shut off after it was on for about 3 mins or so.
  • robertarlt Jul 25, 2008
    I am having the same problem. The only thing i have not noticed any problem until we shut the tv off went to the store came back and it wont turn on light comes on for couple of seconds no screen or sound then green light goes off and a clicking sound...
    Sergeant:
    Champion:
  • 250 Answers
You need to adjust the votages going to the crt's. As the flyback transformer starts to go out the voltages to the crts can go up and down causing the tv to shut off. It also causes red, green, or blue arced lines to show up on the screen. It can also cause some color fading in and out or flickering. Adjusting the voltages can fix the problem temporarily but in the long run it's a good idea to replace the flyback. Make sure you read up on how to do this safely.
Posted on Jul 21, 2008
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WT-46809 Powers Off; Code 2-2
The 2 fuses you mentioned are associated with the convergence IC. If they are open then the convergence IC is either bad or you have a "cold" solder joint on the IC.
Feb 01, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi hdtv Problem started with convergence problem now tv wont turn on or reset
the convergence ICs and the two pico fuses F9A04 and F9A05 need replacing if you have the ws or wt series rear projection HDTV
Nov 26, 2008 | Televison & Video
Mitsubishi wt-46809 rear projection
see if the ics warm up ...out your hand on them if so they getting power.. if cold you lost a resistor or 2.
Sep 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
CAYPIANAN@YAHOO.COM
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi wt-46809 not turning on
Your convergence amp ICs have most likely failed and that will shut the TV down. You need to replace both convergence ICs they are both STK392-570 you can get replacement ICs with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jul 18, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
