Question about Sears 61301 Gas Kitchen Range
Galaxy 61301 how do you re-light the oven on a galaxy stove?
It is in the broiler at the bottom of the oven. Get a flashlight when you open the drawer. Look towards the back and you will see the pilot unit. The pilot lights go out all the time on these crappy cheap ovens.
Posted on Sep 14, 2008
Oven heats properly, but the broiler element does not heat or even get warm. Controller lights up and says broiler is activated. Galaxy stove with ES100/105 electronic oven control.
Broil element can be tested with a meter by a competent service person or by yourself if you are handy. Be sure unit is unplugged before doing any service yourself. If element tests good, then clock / control will have to be replaced
Sep 27, 2017 | Ovens
I need to know how to light the oven? Does it have a pilot light like the stove top
most stoves do not have pilot lights but work from a pizo ignition system
when you turn on the gas knob ,the first action is to energize the pizo and that continually sparks to ignite the gas at the hob
the same is with the oven
ovens should be lit with the oven door open and once lit then the door can be closed
Jun 07, 2015 | Sears 61301 Gas Kitchen Range
Need the power cord for a galaxy gas kitchen 30 inch stove
most cords can be bought at the local hardware store . Most are universal . High voltage 240 volt Ac. They may have three or four wires . Most though are three prong receptacle
May 27, 2014 | Sears 61301 Gas Kitchen Range
GAS RANGE CONVERSION TO PROPANE
Try this site for the conversion factor: http://www.onlineconversion.com/pressure.htm . 1 Water Column [inch] = 0.0361 pound/square inch (PSI) (to a reasonable number of significant figures).
I hope this helps.
(However, your stove and tank must be very different than mine. We didn't need to adjust the inlet input for the max PSI, just make sure that the incoming pressure was in the standard range for LP. New stove installed last month after old one suffered a failure of the oven valve.)
Jul 13, 2010 | Sears 61301 Gas Kitchen Range
Where's the pilot light for the oven on a Galaxy gas stove model 790.61031100
The Oven pilot is attached to the burner(aka-Thermal bulb). its on the base of the burner tube. There's an elbow piece that connects the burner tube(aka-Thermal bulb) to the Safety valve. its right in between these two parts, attached to the elbow.
Jun 21, 2009 | Ovens
Paint on stove top is coming off.
with smaller spots you can use appliance touch up paint and it should hold paint down and keep spots from getting bigger. Depending on how old the range is your landlord might be able to order a new top. I would voice my concern to the landlord and see what they might be willing to do to appease your concerns.
Jan 16, 2009 | Sears 61301 Gas Kitchen Range
Galaxy model# 790-61081892
Hi try direct energy they might stock these parts or know some one who might
Aug 11, 2008 | Sears 61301 Gas Kitchen Range
Pilot light
Ok the OVEN pilot light is located in the broiler part of the over (at the bottom) If you open the broiler and get a flashlight you will see the pilot light unit for the over at the rear on the top. What a cheap piece of **** these Galaxy ovens are.
Nov 21, 2007 | Sears 61301 Gas Kitchen Range
Nat gas to propane conversion
With the gas turned OFF, you will need to find the gas regulator on the range. It will located in the back of the oven along the bottom somewhere. It's usually a square shaped valve with a nut on top of it. The gas valve orifice is located under the nut. All you need to do is remove the nut, take the orifice out, flip the orifice over and re-install to convert from one type of gas to the other. It should be marked which side is LP (propane) and which side is for Natural Gas. LP will have a smaller orifice opening than Natural. You will want to make sure the orifice size you are using is facing UP, then screw the nut back on the regulator. You will also have to do this for all the surface burners (if you haven't done so already). You will know if you have the orifice turned the wrong way because the flames will be too high, the oven will get way too hot and there will be soot everywhere. Hope this helps you.
Aug 11, 2007 | Sears 61301 Gas Kitchen Range
Sears 61301 Gas Kitchen Range Logo
345 people viewed this question
Top Sears Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Sears Kitchen Range Expert? Answer questions, earn points and help others
