Question about Dymo Office Equipment & Supplies
Label is printing but it is dispensing 4 extra blank labels.
  • Dymo Master
  • 2,794 Answers
If you are using Avery labels or an euquivalent. Go to avery.com and download and install the labelmaking program. If you are using Microsoft Office software it should integrate into it as well.
Select the correct form from the label making program and the blank labels should go away if there is something to print on them.
Posted on Jul 21, 2008
  • tpheinrei288 Feb 21, 2011
    My printer is having the same problem. I am using labels from labelvalue.com Would that be a cause of the problem?
What causes intermittent skipping of labels? In the middle of a print job the printer will spew a blank label then continue on with the print job, I'm hoping someone can help me with this issue.
Check your mailing list. Especially check how many invisible spaces are after a name or address. Suspect extra characters are pushing the mailing list into the next page or label and then it will print an extra blank page or label. Seen this happen when I was a Computer System Administrator and had to fix a similar fault for a client.
There is a reveal code option on most word processors that shows up hidden spaces.
May 27, 2015 | Office Equipment & Supplies
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Prints label then prints a blank
This is always a calibration or label template size issue.
Feb 04, 2013 | Zebra Eltron LP 2824 Thermal Printer
Hi. We use UPS worldship and we have a Zebra Z4MPlus printer. It is shooting out a blank label after one label is printed. When there are multiple packages it will spit out way too many labels with blanks...
Things to check for:
1. Make sure that label guides are positioned correctly.
2. Make sure that media sensor is positioned correctly.
3. Make sur that media type is set for non continuous labels.
4. possible sensor fault tis will require an engineer.
Hope this helps.
Aug 22, 2011 | Zebra Office Equipment & Supplies
Why dose printer eject blank labels after every print
If pressing the FEED key advances just one label at a time then the printer works ok by itself. The printer will only do what it's told to do so so if extra labels feed at the end of printing, then you have to look at the printer driver or the label format for something adding the extra labels.
Hope that helps
Jun 16, 2010 | Zebra 140XiIII Plus Thermal Label Printer
PRINTER PRINTS ONE LABEL THEN DISPENSES 4 TO 5 MORE BLANK LABELS. UNABLE TO RESET WITHOUT TURNING UNIT OFF AND REWINDING LABEL ROLL. WE HAVE A COGNITIVE LX THERMAL PRINTER.
Printer needs calibrating. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Oct 10, 2009 | Label Accessories Cognitive Thermal Label...
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
ZQL420+ is printeing an extra blank label with each good label.
Check if you have " send Form Feed after each file" is enabled (or yes) in your print queue
Nov 20, 2008 | Zebra QL420 Thermal Printer
469 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
