Question about Dell Dimension 9200 PC Desktop
It "Chirps" From time to time, my 9200 will, well, chirp or beep. Sometimes it'll be about 40F in the house in the morning, first boot, it'll load up into windows and BEEP or CHIRP at me once in a great while. Other times, like tonight, it'll do it fairly constantly. Still other days, it'll do absolutely nothing out of the ordinary at all. All I can localise it down to is the front 1/3 of the case. Otherwise, the system runs like a champ, like it did a year and a half ago when I bought it.
  • Anonymous Apr 26, 2009
    I have exactly the same problem.  A short "Chirp" (less then a second) and then hours noting, and then again.  I've had this issue for more than a year now.  The PC runs very well and I'm 99,99% sure I'm Virus-free.
    It's not mechanically from the fan, I'm positively sure of that.
    Great if you could help !!!
    Problem Solver:
  • 13 Answers
Check to make sure all your bios settings are right if not you have a hardware conflict somewhere
Posted on Jul 21, 2008
  • 329 Answers
I do not know how old your Dell is but fans will cherp, eventually they will squeak and if not changed will stop being a fan and cause damage due to over heat of chips. Check your power supply fan, some times they run slow if they are going, also the CPU fan needs to turn all the time. Pull the side cover off and what the main chip fan (CPU fan) see if it runs on start up it should and also some boards such as video boards have fans on the chips. I would suspect a random chip is a fan. Not expensive to replace fans, Very expensive to replace boards or CPU..
My computer chirps and doesn't start up when I turn it on. If I take the battery out and put it back in, sometimes several times it will startup normal. What could be wrong?
The "chirps" can indicate the nature of the problem. How many chirps? Is there a pattern? You can also tell more by running the builtin diagnostics. This explains troubleshooting steps and section 4 covers running the diagnostics.
Feb 07, 2017 | Dell Computers & Internet
Lanson smoke alarm
You should buy a new fire alarm. As you mention it also looks annoying to me and think safety first it can confused you if real accident happend.
Mar 14, 2014 | Home
No chirp when arming vehicle
Either your siren is broken, not properly grounded, the system is in valet or, the chirps were deleted. To add chirps, turn the key on then off, immediately press and release the valet switch three times. If the chirps were off you will hear one chirp from the siren.
Feb 14, 2014 | Prestige Remote Start
How do you re program a replacement remote for the APS997A
To program remote; ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off.Test
May 27, 2011 | Car APS997A Two-Way Remote Start and...
Stop horn from beeping on every action
You can delete the chirp from the unit: turn the ignition on, then off, press and release the programming switch three (3) times. You should hear two chirps. You should hear no sound from the unit now when commands are sent. You can put the chirps back in the same manner.
Oct 17, 2010 | Prestige Remote Start
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
Ignition on, press and release programming switch three times,you will hear one chirp ( channel1), press lock button on remote, press and release switch 1 time ( two chirps, channel 2) press unlock button, press and release switch 1 time (3 chirps), press green remote start button, press and release switch 1 time ( 4 chirps),press option button. Turn ignition off, test.
After pressing the corresponding buttons on the remote programming sequence above ,you should hear confirming chirps from the alarm.
Sep 29, 2010 | 5BCR07P Remote Replacement Transmitter for...
Audi a4 turbo chirps when car is started
Could be the belt(s).
If not that, could be a loose hose coming from the turbo. If it build boost and the hose is loose, it'll chirp. At least, it would on my turbo bike. Sounded like a balloon releasing air when the neck is pinched.
Dec 24, 2008 | 2002 Audi A4
Dell Dimension 9200 PC Desktop Logo
162 people viewed this question
Alun Cox
