Error code on a canon IR2570Ci printer / stroke scanner. The code number is E000020-02a9. Could someone tell me what this means please, what the error is
  • 18 Answers
SOURCE: Canon Image Runner C3200
Can you give any more background, this could be a firmware/system software issue. There is anew network card that only works with latest system software. If you have upgraded the system software down grade agian to get working.
Posted on Oct 15, 2007
SOURCE: Sharp -AL1644 flashing L6 error
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Posted on Mar 18, 2008
  • 168 Answers
SOURCE: Error code E000070 0001
this is a error code for the transferf sheet either it is ripped or not turning anymore
Posted on Feb 03, 2009
  • 118 Answers
SOURCE: Error code E000732-0001
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
Posted on Jul 01, 2009
SOURCE: Canon Pixma MP160 All in one deskjet printer Error code E 2
Please can you tell me what the error code E 2 & 7
Posted on Oct 22, 2009
Hi, has a Canon IR2570CI copier. Shows error code E00748-4000 when trying to start the machine. What shall I do to make the machine start properly again. Best regards Klaus Garde Nielsen
Canon IR2570ci Error Code
Symptom
E732-0001
E747-DF00
E748-4000
Cause
Film coating preventing effective contact between Main Controller and Sub Main Controller SJ-A.
Main Controller PCB (Sub SJ-A)
Action:
Clean the contacts of the Sub Main Controller PCB (power circuit board)(SJ-A) using methanol.
Apr 29, 2008 | Office Equipment & Supplies
Error code e000020-02a2
i have canon ir2570ci but shows error code E000020-02a2
Aug 31, 2013 | Canon imageRUNNER C3170U Color Copier
Error Codes E000002-0102
pls change tefloon is over heat
Jul 04, 2013 | Office Equipment & Supplies
Error e42
It mean you have damaged scanner. Disassemble the printer then change flex cable, if problem still exist try to change scanner.
More clear about error code for Canon printer :
CANON MP Series Error Code
Oct 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon printer S200SPx error code 5600
The user manual does not talk about specific error codes. From other forum I belong to, it looks like it may be a bad printhead. If that is it, Canon says to call support. I suspect the cost of a new printhead would be more than the printer is worth.
Jul 31, 2009 | Canon S200X Ink-Jet InkJet Printer
Jul 01, 2009 | Canon imageRUNNER C3220 Color Copier
Error Code Canon MP160
p 87 of manual--
e2-- reload paper, press black or color button on printer
Jan 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
117 people viewed this question
jasbo
jasbo
