Question about Bosch SGV56A13 Built-in Dishwasher
Bosch dishwasher SHU66C02UC
I have a bosch dishwasher SHU66C02UC the timer ( electronic timer ) will not change and you can hear it running but has no water in it. Please let me know what you think. Hi have
    Master:
  • 382 Answers
HI,
Well You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dishwasher is still running the drain pump, then with a wooden spoon raise the red plastic stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dishwasher start filling, then run cooking oil through the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) through the dishwasher to remove this..
Please post back for how things turned on or for further help..Thank you!
Regards!!..
Posted on Jul 22, 2008
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jul 22, 2008
    Enter you model No at search tab and click search to see also other parts availability
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DISHWASHER?
Bosch dishwasher SHU66C02UC - small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
  • LORETO LACARON
    LORETO LACARON Jul 22, 2008
    Dishwasher does not fill with water or it drains while filling
2 Suggested Answers
textonor
  • 130 Answers
SOURCE: Bosch dishwasher SHU66C02UC
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Posted on Feb 02, 2008
Model SHU66C02UC /14
never saw one with cotton pad . call a repairman
Jun 09, 2015 | Bosch Dishwashers
Electric smell bosch dishwasher
Do not use this appliance until you have check if it is one of the bosch dishwashers subject to a recall repair. Use the link below to check
http://www.repairaction.co.uk/bosch
Apr 16, 2013 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch shu66c02uc dishwasher has much longer cycle run times than it did the first 4 years we had it, also stays stuck on 1 or 2 minutes remaining for 30 minutes or more. Just doesn't clean any more.
Sounds like the filter is clogged. If you can and want to try to fix it yourself open door all the way after unplugging it or disconnecting power. Look under the top and you will find screws that you can take out and pull cage out. Then look at all of the drains, filter(s) and see if anything is clogged.
Jan 05, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have the SHU43C02UC model - it is white. It is 3 years old. If I turn it on any cycle it just runs for hours it does not stop.I have to stop it manually and drain the water out. Thanks Lisa
Hello Lisa and welcome to Fixya,
The problem you`re describing is a very common one with Bosch built dishwashers, unfortunately. My first suggestion would be to phone an authorized B/S/H/ service provider (Bosch) It can be a fairly involved repair, I`ll explain why as best as possible...
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control,( 99% of the time ) specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sits and runs & runs ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on thier behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
May 14, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Feb 08, 2010 | Bosch SHU4006 Dishwasher
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Apr 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Jan 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
If you coud describe where you hear the noise that would be helpfull. the noise could be somethig hilling one of the spray arms or something stuck in the pump impeller. if you only wear it when it is only in a wash cycle I would say it may be someting in the wash pump. But also make sure the spray arms are moving freely
Jul 19, 2007 | Bosch 24 in. SHV66A03 Built-in Dishwasher
Bosch SGV56A13 Built-in Dishwasher Logo
244 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
