Question about E-Machines eMachines Desktop PC
Startup disk Hi. How can I obtain another copy of the start up disk for my emachine? I recently crashed and it will not load windows. It asks for me to insert the start up disk for my emachine which I no longer have. Is this possible to get another disk?
    Problem Solver:
  • 13 Answers
Http://www.recovery-cds.com/laptop/search.asp?keywords=eMachine+Boot+CD+Disk&recor=1
http://www.spotmau.com/products/package/full.htm?gclid=CJvTiaOn0ZQCFRIdagod8gUbkg
Posted on Jul 21, 2008
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
Tip
Windows startup does not complete.
Hi.
If The BIOS is showing initial splash screen, and completing POST test correctly, but Windows Startup does not complete, and you are in one of the following situations:
  • You get a black screen with a cursor blinking.
  • You get a black screen with test or command prompt.
  • You have a blue screen with a warning message.
  • Windows keep restarting.
  • Windows is freezing.
Any of the condition described must occur before getting to login screen or to Windows desktop, or the problem is other than the one described here.
If you get a message saying Operative system not found you may also be in same situation. Only in that case the disk may also be physically damaged, and you may have lost your data, or disk may need replacement.
The conditions above usually tell us that the Windows system files needed for Startup are corrupted.
Windows cannot load the files anymore and will hang on with the cursor blinking.
When this happens you need to reinstall the operative system.
To start you can try loading the system in safe mode, by pressing F8 on Startup.
If the computer is starting in safe mode, try doing a system restore to a recent date before the problem started. This will be faster than installing a fresh system, and most of your settings will be preserved.
You may find out that when the system does not load, most computer will not even start in safe mode.
Check also that there is no CD, DVD or floppy inside the computer, also disconnect any connected USB device, apart mouse and keyboard, and attempt starting the computer again.
If all that does not work, then you will need to reinstall Windows.
Installing Windows is not a complicate operation, all you need is the computer recovery disk, or a Windows install disk valid for the licence number printed on the Microsoft Certificate of Authenticity sticker.
If you use a recovery disk, remember to choose partial recovery, so that the original data contained in the hard disk won't be deleted.
Using Windows generic disk you will need to choose Update Recovery if asked, install the system on top of the same directory (eg: C:Windows), and you will also need to choose Leave System File Intact, when asked by Windows setup.
Using a Windows generic disk you may also need to install additional drivers, that usually are available for download from the manufacturer website.
Even choosing a partial recovery , or an update install, some of the installed software may be affected, and may need a fresh setup.
Another way to proceed is installing a copy of windows into a different folder (eg. C:/Windows000), and choosing to leave system file untouched.
This will reinstall system files hosted in root folder, and sometimes may bring back to life the old system.
In that case you will be asked what system to start from Windows boot manager on Startup, your old system will be the second one.
Using this method is better to remove the new installation Startup from boot manager after installing and testing that the old system is back at work. This is done editing the system hidden file Startup.Ini, hosted in root folder. The file is a text file.
If you have important data inside the hard disk, it is always advisable to copy all data onto an external media. Even if the procedures described normally do not delete your data, when doing maintenance on a computer there is always the chance to loose data.
If the computer is not starting because of a system problem, the data can only be recovered using a boot disk, or physically removing the hard disk drive from computer, and connecting it to a different computer (an external enclosure may help).
This same instructions broadly apply to all recent Windows operative system, Windows seven setup is slightly different from the procedure described here.
on Dec 11, 2009 | Microsoft Windows Vista Home Premium with...
How can i perform a factory restore on my emachine w3619 without my start up disk..my computer will not load my sims 3 game and it used to be able to i tried everything (including system restore) to fix it
ask emachines for duplicate dvds of your startup disks.
your os is Genuine Windows Vista® Home Basic
any copy of that would work, but you wouldn't have the cyberlink or other software
before doing that
you may first try checking for viruses or startup programs
and then reinstalling any game software
maybe your sims is broken. verify that it works on another machine
Jan 13, 2011 | Computers & Internet
Need to reload windows xp on Emachines PC
Yes all you have to do is.........
Turn off the Computer
Turn back on and Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
The recovery will load and display a menu of options:
Full System Restore (with Backup): This options will move all Hard Disk contents to the "c:\My Backup" directory and install a new copy of Windows. This option preserves your existing data files, however all applications and settings will need to be reinstalled. This option requires 4GB of free Hard Disk space for the new OS.
Alway suggest backing up your data before you do any recovery
Mar 19, 2009 | E-Machines eMachines Desktop PC
Emachines t5212 system restore backup files, please help!!
If you only your files to be copied in the other or any storage disk then you can remove the hard disk of your machine and then attached it to the other functional machine. in there you can browse and copy all the important files. after copying all your files then you can take back the hard drive to your non functional machine and then install new operating system. documentation found here: http://support.microsoft.com/kb/316941
tell me if something wrong with your system when applying the solution.
melnavz
Feb 05, 2009 | E-Machines eMachines Desktop PC
T2899 emachine startup cd needed ill pay$$$
what you need is to reinstall windows not a start up cd any win xp cd will do
Jan 11, 2009 | E-Machines T2899 PC Desktop
Emachine 3623 boot up??
probley computer crash ,dont say what system you using try getting a onther copy of windows opeting system put in you cd drive and should pick it up, if not go into boot sequence in bios and d-drive your boot up first it should give you fresh operating system and maual load the drivers for your hardware manual if it has picked up
Oct 05, 2008 | E-Machines eMachines Desktop PC
Service pack3 crashed puter - after reinstall machine thinks extra hard drive is a disk drive.
You can get to the BIOS by hitting DEL or F2 at start up.
However, that does not have anything to do with a drive letter.
Drive letter designation is set in
START>SETTINGS>CONTROL PANEL>ADMINISTRATIVE TOOLS>COMPUTER MANAGEMENT>DISK MANAGEMENT.
Hope this helps.
Sep 06, 2008 | E-Machines eMachines Desktop PC
Im trying to install win xp on a used computer
Are you useing the windows xp cd?
Enter the xp setup when asked "press any key to start from cd.." (press a key here so you get into the blue windows installer)
And follow the steps, do you get problems there?
Jun 05, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
203 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
