Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
BISSELPRO HEAT CARPET CLEANER
I HAVE TAKEN THE TOP HANDLE OFF, SO I CAN CLEAN THE HOSE OUT, BUT I CAN'T GET THE TOP COVER OFF. DOES IT JUST POP OFF. I'VE TAKEN ALL THE SCREWS OUT.
    President:
  • 1,673 Answers
With the top part of the handle off, lay the handle back and at the top in the middle, there is a catch, just push it in to release it and the front of the handle will come off.
Posted on Aug 10, 2008
No spray onto carpet
You might have a clog in the heater. The upholstery tool water does not go through the heater. You will have to access. The heater and remove the cover to clean out the channels in the heater
Mar 04, 2014 | Bissell 25A3 Proheat Upright Deep Heated...
My Bissell ProHeat Pet Carpet Cleaner will not spray water. Can you help me troubleshoot this problem?
I have cleaned the heater but still having the problem so what can I do
Feb 26, 2012 | Bissell Vacuums
Dont have a manual how do u connect the hose to it
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
May 05, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How to attached stair cleaning attachment
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover F5835900 Upright Steam Vacuum
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Replace accessory hose
i There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
Raise carpet cleaner handle to upright
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaner does not dispense
Check to make sure that the back end of the top housing is tight against the bottom, Sometimes they break loose. Make sure that the gasket at the bottom of the tank is on and is in place. Does the hand spray work? If it does then the heat inside the handle is plugged up. Pump belt broke or is slipping, could have a bad pump. The cap for the flow indictor is leaking air. There are alot off reasons why it may not be spraying.
Nov 10, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell ProHeat Carpet Steam Cleaner stopped spraying.
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
Sep 29, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
57 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
