Question about Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
  • thebigread Jul 30, 2008
    I contacted Breville. While I was waiting for a response from them, I cleaned the one cup and two cup filters with a toothbrush and the machine worked. Breville's solution was to clean the filters, which I had already done and it was the right solution. Thanks, Guru.
  • jsebor Aug 02, 2008
    Machine has never been plugged in. Recieved as a wedding gift last year. Tried to work last night and pump not working???? anysuggestions???
  • 515 Answers
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Posted on Jul 30, 2008
Steam wand it NOT clogged...but steam & water coming out at connection point and not coming through wand. I took it all apart to clean it and now this is happening...
You either missed a seal when reassembling, or did not get a tight seal (may be "cocked") when you reassembled it. In other words, no pressure due to lack of seal.
Mar 06, 2015 | Breville ESP8XL Cafe Roma Stainless...
I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
May 20, 2010 | Breville ESP8XL Espresso Machine
How do I get my breville cafe roma espresso machine to pump water out of the water tank and through the machine? It won't create steam or brew coffee and the water level in the tank won't deplete when the...
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Dec 27, 2009 | Breville ESP8XL Espresso Machine
Breville Cafe Roma esp8xl
push down on the water reservoir. ours took a while to prime.
Aug 15, 2009 | Breville ESP8XL Espresso Machine
Cafe Roma producing more water than steam
you really need to decalc frequently, at least every 2 months. after it goes too long, you will see that problem. have not figured out yet how to fix it.
Jun 18, 2009 | Breville ESP8XL Espresso Machine
Cafe Roma Expresso/Cappucino machine
My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
1,361 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
