Question about Le Creuset Kone Electric Kettle
My detatchable kettle is not getting electricy from the cord to the kettle
  • 417 Answers
If you are in the UK it could be a blown fuse in the plug, if not a loose wire or contact in the base..
Posted on Oct 17, 2008
No power to kettle fuse ok
Very likely it is a broken wire in the supply cord hidden by the plastic covering or an open connection within the kettle's element contacts. Most kettles are not consumer serviceable. Safest and most economical solution is a new kettle.
Jan 24, 2017 | Kitchen Appliances - Others
Cordless electrica tea Kettle---cord on heating element gets hot when in use.
  • Be careful, the type of wire in use may melt the insulation and cause a short/shock.
Jul 24, 2015 | Cuisinart Kitchen Appliances - Others
Information to question already asked the fact the power is lighting both lights up but no noise of starting to boil does this kettle need a new element and if so where can a get it fixed.
You are not specifying what make it is but you hardly get replacement elements for kettles any more. The fact that you can see that power is available at the kettle it is indicating that it might be the element being defective. Had it been it switched on without any water in it? If it is the old type where the electrical cord gets plug in at the kettle check if it is well plugged in otherwise it is time for a new kettle.
Apr 09, 2015 | Kitchen Appliances - Others
I have a model RK 17 Cordless electric jug kettle from cuisinart that I just love because of the old fashioned design. I need a new base because a mouse decided to chew the cord and was incinerated.
i HAVE THE BASE IT WORKED FINE, MY DAUGHTER COOKED THE KETTLE WHEN SHE TRIED TO HEAT IT ON THE ELEMENT, now I need to find a new kettle! ONSCHMITT@SHAW.CA
Jul 18, 2012 | Cuisinart RK-17 Cordless Electric Kettle
Electrical cord on kettle shorting out and smoking. is this a common problem?
No.
Power cords should not get hot, short or smoke. This is a fire hazard and it should not be used until a replacement is found or the the kettle is checked out for safe operation.
Be smart - be safe!
Apr 26, 2011 | Microwave Ovens
How to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
The pull cord for starting the cutter has detatched
normaly there is 4 bolts holding the cover on take them out and the pull clutch in under there,,, put the string back in the cover and tighten the clutch up first so it pulls the strin in when you let it go,,,tiy a good knot in the pull start string or you will just pull it out again!
Jul 01, 2010 | Ryobi Garden
Power cord overheats
The thermostat is not shutting the unit down and cycling it on/off as it should. This will cause the power cord to overheat and it will catch fire. STOP using this unit and either replace it or have it repaired. More than likely cheaper to just replace it.
May 30, 2010 | Krups FLF2 Cordless Electric Kettle
Need new base
Try http://www.support.philips.com/support/service/onlineStore.jsp?userCountry=us&userLanguage=en
At the top corner you can choose your country, and hopefully you'll be able to locate a local Service Center
May 16, 2010 | Philips HD4671 Electric Kettle
Replacement Power Cord
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the pot with you to make sure you are getting the correct cord.
Dec 28, 2008 | Le Chef Electric Shabbos Hot Water...
Le Creuset Kone Electric Kettle Logo
131 people viewed this question
Top Le Creuset Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Le Creuset Kitchen Appliances - Other Expert? Answer questions, earn points and help others
