I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key when ready." When I do that the error message just keeps coming up.
    President:
  • 1,257 Answers
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Posted on Jul 21, 2008
    • Deeps . Jul 21, 2008
      RESOLUTION
      loadTOCNode(1, 'resolution');
      To resolve this issue, use one or more of the following methods, and then restart your computer:
      Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
      Change your computer's boot sequence. To do this, you must change your computer's setup and the option that controls which device your computer uses to start from. Make sure that you select a device that has boot files (or operating system files) installed.
      If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP) on the drive.
    HP Pavilion PC Model 8595C,beeping while power is on,nothing on monitor
    Try removing the left side of your case (should only have 2-3 screws holding it on), locate your memory sticks and remove them. Put them back in snugly and make sure the clips at the top and bottom are closed onto the memory and then try booting again.
    Oct 17, 2013 | Computers & Internet
    Our new hp monitor won't restart after computer is taken off sleep mode the screen will show a partial screen saver but it won't display icons until you turn off monitor and turn back on
    is this only your monitor or is it your computer as well
    test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
    make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
    even something as small as an electrical extension or a faulty fan lead can cause this problem
    a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
    make sure your graphics card is securely seated with no dust in its socket
    Restart your computer
    During the boot process you will see on the screen to press a certain key to enter setup
    Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
    hope this helps you
    Sep 13, 2011 | HP Computers & Internet
    HP laptop - Symantec Endpoint Encryption.. I bought a computer from an ex-teacher. I can't log into computer because it says: "The computer is locked for failure to communicate with the Symantec...
    try inserting a bootable dvd and on restarting boot from the dvd.reove all the previous components from the system by formatting it and install fresh version of windows.
    good luck
    Sep 02, 2011 | Computers & Internet
    Tosheiba laptop vista recovery disk won't load. I put image files on c drive try to start try to ruin tosimagex new errors
    Hi! Welcome to www.fixya.com.
    What you have to do is to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically. Check your recovery if its running on other pc. If not. call your manufacturer and get a new recovery disc.
    Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
    Jul 19, 2011 | Toshiba Satellite A215-S7422 Notebook
    How to format and instal windows xp to hp compaq d530 desktop pc???????
    Hello, just start the computer an while starting (bios post) touch the del or esc or f2 or f4 just try one of theese when you can enter the bios menu then you go to start order and you choose first dvd/cd rom and second hdd0 always go to save it and exit, the computer wil restart then put in the cd/dvd rom drive the windows cd, restart the pc and when it says some thing like push enter to boot from cd/dvd rom then you push on enter and follow the instrucction till the end!
    success!
    Apr 03, 2011 | HP Compaq d530 SFF PC Desktop
    Hp computer screen froze on blue startup. keyboard and mouse not working either. unplugged everything and still nothing.
    restart computer and as it boots up hold down the F8 key to get to the boot options screen and select start with last known configuration and see if windows will start up
    Jan 21, 2011 | Computers & Internet
    My hp pavilion zd7000 wont boot up, how do I get it to turn on. Had some kind of Java virus was trying to reboot computer, and now it won't turn on at all. Computer illiterate here almost.
    hi
    becoz of virus you have re install your OS
    you have boot from Windows CD just put into ROM then restart your computer it will boot from the CD if not then you have go in bios and change boot option
    Aug 04, 2010 | HP 336084-6C0 - HP Pavilion zd7000...
    Computer crashed and won't boot. restarts before it loads
    Firefox is a bad virus program three thing to do
    1st safe mode
    if not, reboot vista disk.
    If can't you need to go to bios to run cd to restart fresh program. but remember if this you loose all media.
    Dec 05, 2009 | HP Pavilion DV9500Z Notebook PC
    Today while a user was trying to get online using IE, the machine froze and the monitor went blank. The monitor had red lines appear about 1/2 inch apart and froze. The machien qwould not soft boot. I did...
    Your startup got corrupted. If you have an emergency boot floppy, you should be able to get to DOS. This may not work unless Floppy is in your Boot order. If your lucky, you have a cd/dvd in the boot order. Try to put your original XP or Vista disks in and see if you can boot. You can then see files.
    Nov 10, 2009 | E-Machines T5048 (7136) PC Desktop
    Computers & Internet Logo
    193 people viewed this question
    David Payne
    David Payne
