Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Motorcycle bag install
Quick release harley davidson hard bag install. How is it done. the instructions are beyond me.
    Problem Solver:
  • 12 Answers
Look at the pictures!
Posted on Aug 20, 2010
    Scholar:
  • 150 Answers
Im not being a smart *** but if you can't figure out how to install the brackets you need a shop to do it. Find an independent shop don't pay HD prices. I work at a shop and even I have to read the directions and sometimes they are in greek so don't feel dumb.
Posted on Jun 14, 2009
4 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: harley davidson motorcycle 1971
Some of us here do work on Harley's. You are correct on the gap, and here's enough to get started on the timing. Pull the spark plugs and set the point gap to .018 for 12volt systems, .022 for 6 volts, on the highest point of the point-cam lobe. Turn engine over until the front cyl point cam lobe (the small one) is coming around and getting ready to open the points. Remove the timing plug on the engine and gently turn the engine on the kickstarter until the timing mark appears in the hole. On most earlier big twins it should be a straight line, get it approx. in the center or slightly before.
Posted on Aug 06, 2008
v2iper
  • 150 Answers
SOURCE: Horn does not work
First check the two wires going to the rear of the Horn. One ground One Power. If they are connected to the horn then check the ground wire it comes lose most often. If you have power to the Horn then the Horn is defective. If you have no power to the horn it is necessary to trace up to your switch houseing. Usually the problem is ground, I have found defective horns but not often. You can take the horn off and using a battery and wire touch the two prongs in the back of the horn.If it works then the problem is either ground or power. Make sure horn is grounded. Usually the problem is a grounding one. Good Luck.
Posted on Mar 28, 2010
Testimonial: "Thanks I will try this. L. Pease"
SOURCE: KNG America Harley Davidson Motorcycle Lamp Repair.
Big tip 'o' the hat to harleyds96 for giving me the impetus to get after it and tear the lamp down and sort it out. You'll need a precision Phillips #1 screw driver to remove the 8 screws. You'll have to pry the 4 little rubber pads off that double as screw hiders
Once you've carefully separated the bottom plate from the rest of the pedestal, you'll see that you need an extra set of hands to hold the plate, amber glow ring, and the main lamp body with, while you fight with the little fuse box in the center of the lamp.
They all have to be held, because the speaker wire runs through the amber ring to the bottom pad, and can't be unplugged, 'cuz it's soldered. No spade connectors, nah, that'd be too easy - and complicated. They'd like to make it so much easier to toss out another $80 for a replacement, 'cuz you stupidly lost the receipt!
So now that you've got everything separated, you discover that there's another two screws holding the ends of the fuse box to the main body of the lamp. Yes, they must be taken out too, so's you can properly fight with the four little clasps holding the fuse box together!
If you can get it popped open without ripping wires from their solder connection, you're a neurosurgeon! I lucked out, 'cuz I did the operation whilst sitting at the computer desk, so the bottom two pieces could rest on it, without ripping the speaker wires off of the speaker, while at the same time, the main body of the lamp was resting in my lap.
Now that you've succeeded in getting the box open, you'll see that you have that little fuse there, that the Harley lady mentioned above found. It's stamped - 1A/250 V, which, I suppose, would mean it could be plugged in down undah, where they use 240 volts.
So I'm going to see if I can find a 2A/250V fuse somewhere, and if that's too hot for it - TOUGH! I'll have a Harley Davidson plastic patty melt! vonster.vaughn
Posted on Oct 10, 2010
How to assemble harley hard bags ?
They should come with instructions, if you do not have them go to Harley dealer and they can print them off for you.
Jun 20, 2014 | 2008 Harley Davidson FLHX Street Glide
Take off the tour pac
Is this not a quick release?? You can go to a Harley parts department and ask for printout of installation instructions.
Apr 13, 2014 | 2011 Harley Davidson FLHTCU Ultra Classic...
Remove hard bags from 2010 street glide
Harley Davidson Manuals Mark Workshop
Hi Anonymous, it's too bad you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck.
Dec 29, 2012 | Harley Davidson FLHX Street Glide...
Dyna wideglide 15 amp fuse for headlight
Harley Davidson Wiring Diagrams and Schematics
Hi A440visitor, you could have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker, relay or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below. Good luck and have nice day.
Jan 19, 2012 | Harley Davidson Motorcycles
Proper installation of a Harley Sportster windshield. Original HD but not the quick release type.
Hi Danny, for more information about your question please visit the websites below. Good luck and have nice day.
Motorcycle Windshield Install Handlebar Mount
Jun 06, 2011 | 2008 Harley Davidson XL883 Sportster
Looking for sportster hard saddle bag installation instructions
nstructions Difficulty: Moderate Things You’ll Need: Step1 Determine what type of saddlebags you will be installing on your motorcycle. Saddlebags come in hard and soft styles, with each installed in basically the same manner. Hard bags tend to offer more security for your items but are a bit on the bulky side, while soft bags offering a little more flexibility. Step2 Check to make sure that your fender bolt area is clean and prepped for installation of your saddlebags. Both hard and soft saddlebags on Harley Davidsons are installed over the fender bolt area on the rear of the motorcycle, so clearing this area of debris and grime will keep it free of scratches and blemishes. Step3 Install any spacers or lifting brackets before you try and place your bags on your Harley Davidson. These spacers will keep you bags from resting against your exhaust pipes and will avoid damage to your motorcycle and to the bags themselves. Make sure they are installed tightly and spaced properly before mounting your bags. Step4 Open the saddle bag packaging and lay out the included hardware. The hardware will be necessary to properly mount your saddlebags to your fenders, so be sure that you do not misplace it. If your saddle bag comes with a fender mounting bracket, install it along the fender before proceeding. This bracket will be used to hold and stabilize your saddlebags, so it is essential that it is properly tightened and installed. Step5 Hold your saddle bag up to the fender and align the bolt holes in the saddle bag with the bolt area on the fender. Your saddle bag will have mounting holes in the side of the bag that will align with the mounting bracket. Place one of the bolts in the hole and tighten to hold it on. Put the remaining bolt in place and tighten them both securely once they are aligned correctly. Step6 Repeat this process with the remaining saddle bag. The bags should align evenly and be attached straight to avoid any imbalances or shifting while the motorcycle is in motion. Try and wiggle or move the bags to be sure your bolts are tight enough to prevent movement. Step7 Take your Harley Davidson for a short ride. Stop and check the fitting on your saddlebags and look at your bolts. Make sure nothing has moved during your ride and that all of your fittings remain tight. With just a bit of effort, your new saddlebags will make your Harley Davidson the envy of the neighborhood.
Nov 11, 2008 | 2006 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
44 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
