Question about Toshiba Satellite A65-S126 Notebook
Memory for toshiba A65-S126
Can someone please assist me in upgrading the memory of a toshiba A65-S126 from 256 to 1 gb like where the memory is located and how to take out the old memory? Thanks.......
  • josephinem Feb 15, 2009
    Tried to add memory and now the computer will not come back on. There is a beep sound.
The 256 memory is hard wired into your A65-S126, it cannot be removed. location is where the previous response said it is. There is only one expansion slot for upgrade memory, I suggest looking at www.memorystore.com I have bought 3 1GB upgrades from them for the same A65-S126 computer and all have worked perfect. hope this helps.
Posted on Aug 02, 2008
    President:
  • 1,257 Answers
Its in the middle of the laptop at the back side..you have to go through the manual for changing the ram.. there will be 2 locks ,you just have to press and pull it up.
Posted on Jul 21, 2008
How much GB does the toshiba satellite have?
Here is the specifications of the Toshiba Satellite A65-S126
  • Built-in Devices Wireless LAN antenna , Stereo speakers
  • Width 13.5 in
  • Depth 11.1 in
  • Height 2.1 in
  • Weight 7.7 lbs
  • Localization United States
  • Notebook type Desktop replacement (7.5 + lbs.)
  • Wireless capabilities IEEE 802.11g , IEEE 802.11b
  • Processor
  • Processor Intel Celeron 2.8 GHz
  • Data Bus Speed 400.0 MHz
  • Chipset Type ATI Mobility Radeon 7000 IGP
  • Cache Memory
  • Type L2 cache
  • Installed Size 128.0 KB
  • RAM
  • Installed Size 256.0 MB / 1.25 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor SO DIMM 200-pin
  • Configuration Features Provided memory is soldered
  • Storage Controller
  • Storage controller type IDE
  • Storage
  • Floppy Drive None
  • Hard Drive 60.0 GB - 4200.0 rpm
  • Hard drive type Portable
  • Optical Storage (2nd)
  • 2nd optical storage type None
  • Optical Storage
  • Type CD-RW / DVD-ROM combo
  • Read Speed 24x (CD) / 8x (DVD)
  • Write Speed 16x
  • Rewrite Speed 4x
  • Display
  • Display Type 15.0 in TFT active matrix
  • Max Resolution 1024 x 768 ( XGA )
  • Widescreen Display No
  • Color Support 24-bit (16.7 million colors)
  • Video
  • Graphics Processor / Vendor ATI Mobility Radeon 7000 IGP Shared video memory (UMA)
  • Audio
  • Audio Output Sound card
  • Audio Codec Realtek ALC250
  • Compliant Standards DirectMusic , DirectSound , DirectSound3D
  • Audio Input None
  • Input Device(s)
  • Input device type Keyboard , Touchpad
  • Telecom
  • Modem Fax / modem
  • Max Transfer Rate 56.0 Kbps
  • Protocols & Specifications ITU V.92
  • Networking
  • Networking Network adapter
  • Wireless LAN Supported Yes
  • Data Link Protocol Ethernet , Fast Ethernet , IEEE 802.11g , IEEE 802.11b
  • Compliant Standards IEEE 802.11b , IEEE 802.11g
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 (total) / 1.0 (free) x PC Card - SO DIMM 200-pin , 1.0 (total) / 1.0 (free) x Memory - Type II
  • Interfaces 1.0 x Headphones - Ethernet 10Base-T/100Base-TX - 25 pin D-Sub (DB-25) , 1.0 x Microphone - IEEE 1284 (EPP/ECP) - 15 pin HD D-Sub (HD-15) , 1.0 x Parallel - Output - RJ-11 , 1.0 x Network - Phone line - Mini-phone 3.5 mm , 1.0 x Display / video - S-video output - Mini-phone stereo 3.5 mm , 1.0 x Modem - Input - RJ-45 , 1.0 x Display / video - VGA - 4 pin USB Type A , 3.0 x Hi-Speed USB
  • Miscellaneous
  • Features Power-on password , Hard drive password , Security lock slot (cable lock sold separately)
  • Compliant Standards ACPI , Plug and Play
  • Power
  • Power Device External
  • Voltage Required AC 120/230 V ( 50/60 Hz )
  • Power Provided 90.0 Watt
  • Battery
  • Technology Lithium ion
  • Installed Qty 1.0 / 2.0 (max)
  • Capacity 4300.0 mAh
  • Operating System / Software
  • OS Provided Microsoft Windows XP Home Edition
  • Software AOL , Drivers & Utilities , ArcSoft ShowBiz DVD , Norton Antivirus 2004 (3 months subscription) , Toshiba Custom Utilities , Microsoft Office OneNote 2003 , Microsoft Works , AT&T WorldNet Service , Toshiba Touch and Launch , InterVideo WinDVD 4 , Toshiba Notebook Maximizer , Toshiba Speech System , Toshiba ConfigFree , Adobe Acrobat Reader
Sep 13, 2011 | Toshiba Satellite A65-S126 Notebook
Can I upgrade the video graphics card of a toshiba satellite a65 s126?
No, you can't upgrade graphics hardware on a laptop. It's integrated on the motherboard. There isn't room in a laptop case for expansion slots like you have in desktop, so you can't change what's there. All you can do in a laptop computer is make sure you have the most up-to-date graphics drivers, which can be downloaded from the manufacturer's support site.
Jun 30, 2011 | Toshiba Satellite A65-S126 Notebook
My A65-S126 is running slow and was told that if I change the CPU it would speed it up, is this true? Also is the CPU all that I have to change? and where can I find a upgrade that will work with this...
The processor on that laptop is fine, the main performance enhancer would be to top it out with RAM memory and get all the **** ware off of it. Your laptop has 256 MB of ram built into the motherboard with a free slot that will hold a 1 GB module for a total of 1256 MB. Below are the specs for the module...
DDR PC2700 1 GB Module
Use the link below to download and instal Ccleaner 2.27, run the temp file cleaner and the registry cleaner for a faster laptop....
http://www.filehippo.com/download_ccleaner/
Jan 13, 2010 | Toshiba Satellite A65-S126 Notebook
Driver for video & modem of toshiba satellite a65-s126
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
go to website click download in 1st box select portables 2nd box satellite 3rd box your model number hope it helps
Dec 24, 2008 | Toshiba Satellite A65-S126 Notebook
MEMORY UPGRADE
Yes you can upgrade an A65 series to 1 GB of RAM
http://www.crucial.com/store/listparts.aspx?model=Satellite%20A65%20Series
THe module is located under a door on the bottom
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=713852&rpn=PSA60U&modelFilter=A65-S126&selCategory=3&selFamily=1073768663&selModel=713852|PSA60U
Page 62 of the manual for how to change it
Nov 30, 2008 | Toshiba Satellite A85-S107 Notebook
Removing memory from Satellite A65-S126 Toshiba laptop
The built in 256 is integrated into the motherboard, and is not removable. If it's faulty, then, unfortunately, the motherboard will have to be replaced. There's no other way around it.
Sep 02, 2008 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite A65-S126 Notebook Logo
266 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
