Question about Crosley Refrigerators
Crosley Refrigerator Nent196H BM7A81A
This model has been sitting for 14 years and when we moved it up to the patio the fan works but it does not seem to cool the unit, both the refrigerator and freezer.
    Genius:
  • 1,447 Answers
Hi-
Chances are you need to check the freon for the refrigerator. It might dried up. You need to call or bring this over to a service technician.
Thanks for using Fixya!
Posted on Jul 21, 2008
    Genius:
  • 3,422 Answers
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Posted on Jul 21, 2008
    Why does my new Crosley refrigerator smell like oil in the freezer section?
    Get it replaced or paint it lemon yellow. If they argue ask for your money back, if that is a problem contact your BBB and the manufacturer. It comes with an implied warranty to perform.
    May 17, 2017 | Refrigerators
    Whirlpool top-freezer refrigerator makes loud noise
    Do you think it is the fan in the freezer or could it be the water valve when the icemaker is filling?
    Nov 27, 2012 | Refrigerators
    Hi, I have a Daikin Model FTXS35D with RXS 35D 3VNB outdoor unit. Until this year it was excellent, now does not cool as before. Have cleaned filters etc. Could it be a sensor problem. When I...
    Your unit should cool 15 to 20 degrees. 75 return air temp should be below 60 degree supply air temp. If you are not in this range you likely have a refrigerant problem.
    Aug 14, 2017 | Cfm Daikin R410a Split System Air...
    I have a Crosley refrigerator that is about a year old. We decided to replace it because it wasn't big enough. We moved it to our garage and since we've moved it, it doesn't seem to be chilling the...
    If the garage is unheated and the garage temperature is below 50 deg F this is the reason that the freezer is not able to freeze. A refrigerator is designed to work in a heated space. The thermostat is in the refrigerator compartment while the cold evap coils are in the freezer compartment. The fridge thermostat is typically set to around 40 deg F. When the fridge is in a colder environment, the compressor does not need to work that hard to get the refrigerator to temperature. But the freezer on the other hand, will be above freezing.
    To fix this, there are garage refrigerator heater kits available, for just this situation. They are placed in the refridgerator compartment to heat the thermostat. This causes the compressor to run longer, and thus maintain the freezer temperature better. You could get one of these heaters or you could put an light bulb in the refrigerator to do the same thing as the heater. Remember to use a regular light bulb, and not a cfl or led light bulb, they won't generate enough heat. Also remove the light bulb or heater in the warm months unless you want a higher energy bill. Hope this helps you.
    Dec 09, 2010 | Crosley CFFH10W Top Freezer Refrigerator
    I have cleaned the coils this morning, but the refrigerator section does not appear to cool. The freezer seems fine. This is model eti18PKXGWI ser no. 042 9086 eemingly c. 10 years old.
    Your freezer fan has probably quit. On most refrigerators the freezer is the only compartment actually cooled by the compressor and coils. The refrigerator compartment is feed cold air from the freezer compartment by way of a small fan. If you have you refrigerator turned all the way up and the door open you should here the fan running and be able to feel air moving somewere in the refrigerator compartment.
    Sep 05, 2010 | Whirlpool Refrigerators
    Honeywell compact refrigerator model # 88031not cooling.
    Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
    Mar 18, 2010 | Refrigerators
    Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
    If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
    Sep 30, 2009 | Ruud UBHC Air Conditioner
    Refrigerator wont stay cold.Freezer works fine,no frost buildup
    i replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
    Jul 27, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
    Refrigerators Logo
    146 people viewed this question
    Top Crosley Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    fta777
    Colin Stickland
    Colin Stickland
    Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
