Question about Microtek ScanMaker 9800XL Flatbed Scanner
I have a lot of purple lines running through scans
I can't use certain sections of the scanner because the lines run right through the scan.  It's really bad on the top section of the scanner.  I have these large documents I need to scan and just can't get it done.  The scanner is about 8 years old, is it fixable or correctable, or time for a new one?
    Problem Solver:
  • 14 Answers
Don't waste your scanner ! ;-)
First question:
Is the glass platen inside clean?
I think you should urgently do a color adjustment.
By 8 years using the lamp become darker and the light spectrum change in some wave lenghts the intensity.
If you are using silverfast you should use a silverfast calibration target.
Good luck !
Posted on Jul 21, 2008
I cant receive any channels, I have read the entire book many times, it doesnt give specifics on how to perform certain tasks, its vague.
he BC72XLT is a fairly basic scanner, and the manual contains just about everything that you should need to get it up and running. First, though, you need to make certain that you have a current list of frequencies that are active in your area. For a good frequency database, and a lot of other useful scanning information, visit:
www.RadioReference.com
To verify that the scanner is working properly, select and scan the WEATHER band. If you can receive the NOAA weather broadcasts in your area you should be able to pick up a lot of other frequencies as well.
Bill B.
Listening in since the 60o's
Jan 17, 2011 | Uniden BC72XLT Handheld Scanner
Orange line running down page
lift lid on scanner and clean the thin glass on left hand side
you usually find when you scan alot of docs dust builds up and leaves lines down page
Mar 08, 2010 | HP Scanjet 5590 Flatbed Scanner
All my scans have a fine white line running down
This happens due to the failure of one of the "Detectors" inside the "Scan Head" They have a strip of these sensors all next too each other laid across the width of the scanner platen. Unfortunately there is not a lot to be done.
Feb 11, 2010 | HP Officejet 5610 All-In-One InkJet...
My scanjet 5590 was working ok, but suddenly stops scanning right
try reinstalling the scanner softwares and if this doesnot help do a master reset of the scanner
Jul 22, 2009 | HP Scanjet 5590 Flatbed Scanner
Mustek Scan Express A3 USB Scanner
I've had a similar problem with the streaks, lines and color bleeds appearing in the scan. Try uninstalling the all software and drivers for the scanner and reinstall. Worked for me. Have had to do this a couple of times since I've owned the scanner... about three to four years now.
Jan 25, 2009 | Mustek A3 USB Flatbed Scanner
White lines in negative scans
could be the component scanner inside of the minolta , it will need to be tested to determine if the scanners components or a wire strip is causing the problem or the component scanner its self , it sounds like a section of it is out so it will not see anything ------ ---------- in that section
Oct 08, 2008 | Elite Minolta Dimage Scan 5400 Scanner
Black line on scans
the component scanner inside has lost a section of scan because of its circut or the component its self. it will need to be tested to determine the exact cause
Oct 08, 2008 | HP Scanjet 5590 Flatbed Scanner
Scanned sheets divided
In the preference section Uncheck "Detect Multiple originals".
Jun 09, 2008 | Agfa SnapScan 1212u Flatbed Scanner
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Apr 09, 2008 | Office Equipment & Supplies
Canoscan 9950f red line on scan
Try running a calibration. This is done thorugh ScanGear in Advanced mode. Once in Advanced Mode, in the Image Settings section there should be an option for Calibration (you may have to scroll down in this section to see it). After running the calibration, try performing a preview scan with nothing on the scanner glass. If the red line shows up on the preview now, then most likely the scanner needs to be serviced.
Mar 12, 2008 | Canon CanoScan 9950F Flatbed Scanner
Microtek ScanMaker 9800XL Flatbed Scanner Logo
334 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
