Question about Dymo ExecuLabel LM450 Thermal Label Printer
Dymo Label Manager 450D
Help
My 450 will only print horizontal lines that look like bar codes. They do not change as the text is changed. I cleaned it and put new batteries in it but still the same.
Please help.
Thanks
  • Anonymous Nov 28, 2008
    I have the same problem with Dymo Twin Turbo printer, it prints horizontal lines and will use all my roll of paper as it won't stop printing.
  • 19 Answers
SOURCE: won't print
Here is the Dymo site for this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_alp.php?p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.22&p_prods=21%2C22&p_cats=&p_hidden_prods=&prod_lvl1=21&prod_lvl2=22&p_search_text=&p_new_search=1&p_search_type=answers.search_nl
Type "light print" into the search box and the first result is the link you are looking for.
Here is the text of the link:
Poor Print Quality from Electronic Labelmaker trnsp.gif Question I have an electronic labelmaker that is printing poorly. The print on the label is either very light, incomplete, or striped. How can I resolve this?
trnsp.gif Answer Proceed with the solutions listed below if you have an electronic labelmaker. If you have a LabelWriter printer that is printing poorly, click here.
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
If the solutions listed above do not resolve the problem, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) Number.
Obtaining a Return Material Authorization (RMA) Number:
  1. Click the Ask a Question tab at the top of this FAQ.
  2. Fill out the email form completely and include the following information in the Problem Description field:
  • Full Name
  • Full Shipping Address (No PO boxes)
  • Phone Number
  • Date of Purchase
  • Model Name/Number
-hope this helps.
Posted on May 19, 2008
  • 7 Answers
SOURCE: dymo label 400 turbo.
It doesn't use ink so that's not the problem. more than likely it's one of 2 things. 1. you created a custom label layout and the text is just over the edge of it's printable area. Therefore, only hal of it prints. #2 Your using the wrong size label template on the software. make sure that the size you have loaded in your label printer matches the template shown size for size, inch for inch. The printer doesn't know (or care) what label you have showing on your software. It only knows what's loaded in your printer. So for example, if you have a shipping label on the software and put text to the bottom og it, it won;t print if you have an address label laoded in the printer.
Posted on Dec 31, 2008
  • 1602 Answers
SOURCE: Faint Printing
TRY PUTTING NEW BATTERIES IN THE DEVICE AND THE LETTING WILL GET DARKER SO YOU CAN SEE IT
ROD
Posted on Mar 13, 2009
SOURCE: dymo label point 200
Dymo website, Support Tab:
http://global.dymo.com/enUS/TechSupport/default.html
Drop down box and select your product.
Print out you instruction manual.
Posted on May 11, 2009
FixinFax
  • 3085 Answers
SOURCE: Dymo 330 will appear to print a label but nothing
Your thermal head is burned out.
Posted on Jun 13, 2009
My labels are printing vertical instead of horizontal
when you click print check your setting you need to make sure the orientation is correct portratit or landscape
Nov 17, 2013 | Dymo ® LabelWriter® 450 Series PC...
When adding the Dymo labelwriter 450 turbo to Windows 7 machines, the installation completes fine. When attempting to print, an error shows up in the device manager that says Access Denied for the print...
i HAVE LABEL WRITER 450 TWIN TURBO AND I CAN NOT PRINT RETURN ADDRESS LABELS. i HAVE UNINSTALLED AND INSTALLED AGAIN THAT DOESN'T WORK THE RETURN ADDRESS LABEL IS THERE IT WON'T LET ME TYPE ANYTHING IN THE SPACE PROVIDED IT WAS WORKING FINE THEN THE NEXT DAY IT WAS NOT
THANK YOU
Aug 19, 2011 | Dymo LabelWriter Thermal Printer
I want to print a label with two lines of print on it. How do I do it?
To create a two-line label 1. Type the text for the first line and press INSERT. 2. Use the arrow keys to select Second Line and press . A multiline symbol is inserted at the end of the first line, but will not print on the label. 3. Type the text for the second line.
Here's the manual, see page 12 - http://www.dymo-label-printers.co.uk/downloads/LetraTAG-LT100H-Manual.pdf
Jul 14, 2011 | Dymo LetraTAG Thermal Label Printer
My dymo labelwriter 450 says its out of paper when I try to print a label. When its initially connected the printer says "ready" as soon as a print command is made it says it's out of paper....
Hi, I had this problem and found that the labels were rolled up the wrong way, make sure the series of horizontal black lines on the labels are nearest to the left side of the printer as you look at it, this worked for me, hope it helps - Paula
Jun 19, 2011 | Dymo LabelWriter 400 Thermal Printer
How do I change the size of the print on the label
Using the software that came with it modify the font settings.
Changing the Default Font Settings in DYMO Label Software Answer 299 ' Applies To DYMO ' Published 07/20/2005 10:16 AM EDT ' Updated 08/31/2010 05:05 PM EDTHow do I change the default font settings in the DYMO Label Software (DLS)?
Font settings can be adjusted for individual label templates and for the DLS application. Please note, changing the font settings for the DLS application will only affect the creation of new label templates. It does not change the font settings of any previously created and saved label templates.
Changing the Default Font Settings for Individual Label Templates in DLS
  1. Open DLS.
  2. In DLS, click and highlight the text on the label template.
  3. The tool bar above the label template allows you to change various font and justification settings. To change font type and font size you must click on the Font Settings icon: f_f.jpg
  4. Make the necessary changes to the font settings. The Sample field indicates how the text will appear on the label. Please note, the text will automatically shrink to fit if you select a font size that is too large for the address or text object on the label to accommodate.
  5. Click OK after making the necessary changes.
  6. Save the label template. Click on the File menu in DLS and select either Save or Save As. Selecting Save will save the label template with its existing name. Selecting Save As will allow you to enter a new name and create a new label template.
Mar 01, 2011 | Dymo LetraTag QX50 Thermal Label Printer
My Dymo LabelWriter 400 is printing vertically. How do I change it to print horizontally? Thanks
Hi Kaylene, i`ve experience that before.. Just set the print set-up/ preview into horizontal.. The dialog box of print preview will show you the position of your text before printing Dymo Label! goodluck!!
Feb 07, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
Cannot get dymo to print vertically
On mine you use the FORMAT button
Then theUP arrow until you see STYLE
Then press OK
Now press the UP arrow until you see VERTICAL
Now press OK
Sep 15, 2009 | Dymo LabelMANAGER 450 Printer
Dymo lextra tag xr
I was able to find the following error codes, however I realize they are for the Lextra tag QX50. I was unable to find codes for the Xr, so I e-mailed Dymo and will post a comment on this as soon as they get back to me.
For now, here are the QX50 codes, just in case they help:
LetraTag QX50 Error Codes trnsp.gif Question An error is dispalyed on screen when I attempt to print a label with my LetraTag QX50. How can I resolve this?
trnsp.gif Answer Error
Solution
Error 1
(Tape jammed or low battery)
  • Replace the cassette
  • Replace batteries
Error 2
(Big Font cannot be selected with characters in memory)
  • Select another font size
  • Select Big Font before entering text
Error 3
(Big Font cannot be selected with: box, underline, 2 line, or lower case)
  • Select another style format
Error 4
(Memory buffer is full)
  • Delete some of the entered text
Error 5
(Text is bigger than defined length)
  • Specify a longer tape length
Error 6
(2 line cannot be selected with the format)
May 04, 2008 | Dymo LetraTAG Thermal Label Printer
Dymo ExecuLabel LM450 Thermal Label Printer Logo
362 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
