Question about GE JKP15 Electric Single Oven
Bottom /bake element will not come on
The broiler element works fine. The bottom element will not come on. There is power cominging into the stove, but no power shows to the bottom element. I can set the temp on the control panel and push the start button, but the temp never goes up. The element does not turn on. Please help!!
Susan
    Problem Solver:
  • 9 Answers
This is an easy fix. Go to Appliance Parts and tell the guy your model number and he can get you the right element for little of nothing.
Good Luck
Joe Allen
Posted on Jun 11, 2011
  • 95 Answers
Check the connections to the element. If power is going to the element, and it is not working, the element needs to be replaced
Posted on Jul 21, 2008
When baking in whirlpool accubake electric stove model GR475LXMS only the broiler works not bottom element what could be wrong?
The element could be open or the thermostat for the oven could be stopping power from reaching the element
Oct 17, 2016 | Whirlpool Ovens
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Turn my oven to preheat, broiler comes on and not the bottom element. Checked the ohms on element and it did move the meter.
Check the broiler element, and see if get the same reading.
Does the oven heat on normal "bake" settings? If so, the bottom element is fine, and it's the "brain" not telling the bake element to get hot.
Jun 08, 2015 | Ovens
My bottom element won't heat
that is the broiler element and they are not thermostatically controlled . call a repair man
Apr 29, 2015 | Ovens
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven baking element failed, broiler element worked fine. I replaced the heating element and for 1 meal it worked fine. Now neither element works and the light on the panel does not go on. The stove works...
IF you have the correct amount of 220 volts power at the terminal block.then the only thing left is the main control board has failed and needs to be replaced.
Dec 02, 2010 | Tappan Ovens
GE JKP15 Electric Single Oven Logo
298 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
