Question about JVC DR-MV1S DVD Recorder/VCR
Dvd will not eject
Disc is in the dvd player and I cant get it out by pressing then eject button. DVD will not eject
  • Anonymous Aug 14, 2008
    dvd will not eject
  • leckapllaj12 Aug 30, 2008
    dvd will not eject
This used to happen periodically with my unit. I would just unplug it and then whatever was stuck would pop out.
Posted on Sep 21, 2008
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
My player cant eject disc; it say '' eject key is not available this time''
Please perform following procedure to unlock the unit...
- Press the [POWER] button to turn on the system.
- Press the [FUNCTION] button to select "BD/DVD".
- Press the [STOP] and [EJECT] buttons simultaneously on player front panel and hold down until "UNLOCKED" displayed on the fluorescent indicator tube (around 5 seconds).
Hope these info will help, let me know if there is additional question.
May 06, 2014 | Sony Bdp-s185 Blu-ray Disc Player
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Cant get my akai DVD player to play all my cds and dvds
Instructions
  1. Changing Region Code on Oppo and Similar DVD Players
    • 1
      Press the "On" button on the remote control to turn on the DVD player.
    • 2
      Press the "Setup" button on the remote control.
    • 3
      Press the following buttons in this precise order: 9210.
    • 4
      Highlight the text field in the window that appears. Press "0" on the remote control to change the region code from one-region specific (the country the DVD player is sold in) to all regions so that any disc can be inserted and played.
    • 5
      Press the "Setup" button. Press the "On" button on the remote control to turn off the DVD player.
    Changing Region Code on Sony and Similar DVD Players
    • 6
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray.
    • 7
      Press "Clear," "1," "4," "7," "0," "Clear" on the remote control. Press up on the remote control's directional pad until you see "1224" on the screen.
    • 8
      Press "2," "3" and the "Enter" button. Press up on the remote control's directional pad until you see "1401" on the screen.
    • 9
      Press "0," "0" and the "Enter" button. Press the "Return" button. Press the "Clear" button twice. The DVD player is no longer locked into the single region that it was designed for (being the country it was sold in) and is now instead open to all regions and so able to access any disc.
    • 10
      Press the "Return" button. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
    Changing Region Code on Denon and Similar DVD Players
    • 11
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray. Press "Clear," "1," "4," "7," "0," "Clear" on the remote control.
    • 12
    • 13
    • 14
    • 15
      Press the "Return" button. The region code of the DVD player is now changed from being only for the country it was designated for and instead for all regions. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
PROCEED ACCORDING AND FOLLOW THE STEPS. God bless you
Apr 04, 2013 | Akai Dv-px6150k - Multi Region...
My panasonic dvd player shows locked when I tried to eject. I can't eject tehDVD. My kids could have jinxed it. Model panasonic sc-pt550 TQ
There are two lock conditions for this device.
If you can't eject the disc:
Enabling removal of disc
1. Select the DVD/CD function.
2. At POWER ON condition, press and hold down the stop button and the power button on the player for at least three seconds.
(The message, "___LOCKED_" appears when the function is activated.)
If you can't operate the functions:
Enabling operation of selector and disc
2. At POWER ON condition, press and hold down the play button and the power button on the player for at least three seconds.
Hope this helps!
Apr 08, 2011 | Panasonic DVD-S52 DVD Player
Cant get my dvd player to open
As for temporary use you can use a simple method. You may see a small hole below the disc inserting cabin. Push the eject button and have a pin inserted well into the hole. the dvd player will eject in a matter of seconds. Actually, the problem can occur as a result of aging or someone or something must have applied so much force on the player such that the dvd cabin is misplaced. If you cant find the hole, struck the top of your dvd player hard, after pressing the eject button. Two or three tries must help.
Apr 07, 2010 | Sony SLV-D550P DVD Player/VCR
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Dvd will not eject
Try holding down the stop button (black square logo) and the channel change button (upward pointing logo) at the same time for 5+ seconds. If this dos'nt work also press open/close button at the same time as above
Nov 21, 2007 | Panasonic DMR-E55 DVD Recorder
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
JVC DR-MV1S DVD Recorder/VCR Logo
240 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
