10 blinks on this set is not a power supply fault but rather an A-board fault(Main A/V board). Hence replacing power supply would not do the trick. I suggest you return the board and get an A-board for +50$ and I am confident that it will resolve your problem.
Sai.
I have since found a bent pin on one of the connectors, after correcting this The new board gives the same four blinks. I have found that the SC Board is causing the 200 Volt line from the power supply to shut down Should I replace the SD and SU boards as well.
Peter Ache
Will order and replace SC board, will let you know if this solves the problem.
Peter
I replaced the 2 power supply boards and it will not still turn on.
