Question about Panasonic Lumix DMC-LS2 Digital Camera
Bought 8gb memory card - error message
I bought an 8.0gb memory card for my lumix dmc-ls2. When I put it in my camera it just says "memory card error please check the card".
I have lost my manual so not sure if memory card is too big or do I need to format the card or something?
Please help.
Thanks
  • deckspeciali Dec 25, 2008
    i have a sanyo vpc-5500 for my daughter. It started reading card error therfore we bought a new memory card thinking it was the problem. this did not work but the card works fine in other cameras. can anyone offer any suggestions as to fixing the problem she has only owned the camera about a year.
    Problem Solver:
  • 18 Answers
Hi, I suspect that the SD card is to big for that camera as that camera is a lower end camera. You should try the SD card in a camera that is known to be able to handle such a huge card.
Posted on Jul 22, 2008
What is the largest memory card I can use with this camera panasonic DMC-FX9? Is 8GB too large, because this 8GB is give me memory card error. pls what can i do???
This a camera with some years, be aware of that - that camera comes with an 16Mb card...
Try to format the card on the camera;
Also, some brands or models are incompatible - try to use other card and/or other capacity;
Always format the card on your camera.
Hope that helps, good luck.
Apr 02, 2013 | Panasonic Lumix DMC-FX9 Digital Camera
I have a panasonic lumix DMC-FZ20 camera that i installed an 8g memory card but it says memory card error
The DMC-FZ20 works with MMC and SD cards, 2GB or smaller. Your 8GB card is an SDHC card, which fits into the slot but is electronically incompatible.
Feb 22, 2013 | Panasonic Lumix DMC-FZ20 Digital Camera
I have a Panasonic Lumix DMC-FZ7. The problem is it doesn't read the memory card anymore. It keeps saying, "Memory card error. Please check the card." is there a quick fix to this or is this...
Ok, came accross this problem. After searching and searching, I downloaded the user guide ( who knew?! ) and the reason that is happening is because the Lumix DMC-FZ7 is not able to process an SD card bigger than 2 GB.
I switched it to a 1 GB and camera is back working!!
I hope this helps
Jul 15, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
When i insert my 4Gig SDHC card into my Panasonic DMC LS2 camera , it gives a card error message , please check SD card ! What do i do ?
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 14, 2010 | Panasonic Lumix DMC-LS2 Digital Camera
I have a : panasonic Lumix DMC-LZ3 Digital Camera
Page 92 of owner's manual for DMC-LZ3 states "Do not use memory card larger than 2GB".
Jul 04, 2010 | Panasonic Lumix DMC-LZ3 Digital Camera
I can't get my camera (Lumix DMC-FZ50) to take pictures. Every time I turn it on it displays, "MEMORY CAR ERROR PLEASE CHECK THE CARD". I've tried 3 different SD cards from 2GB to 8GB and always get the...
Were these cards from another camera and now you want to start using them in the Lumix? If so, you must format the card in the Lumix to get it to work. This will erase the card so download any pics first.
Jun 13, 2010 | Panasonic Lumix DMC-FZ5 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Panasonic Lumix DMC-LS2 Digital Camera Logo
1,073 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
