My cooper line outside on my air conditioner keeps freezing over causing my ac to blow warm air instead of cold air
    Scholar:
  • 54 Answers
The evaporator coil that is low pressure and low temperature needs an adequate supply of heat to absorb from air passing over the fins or a thin dusting of frost will begin to form further insulating the coil from the passing air and causing more ice to form. First you have to get rid of all the ice by allowing the coil to thaw you can use a heat gun or hairdryer or lamp to speed the thawing but the fins and copper tubing are thin and easily damaged so don't use tools on the coil to remove ice. After thawed the coil needs to be cleaned with an indoor evaporator cleaner ( I also use a small shopvac and nylon brush) Then be sure that the filter is clean and the blower is functioning properly then if the suction line is still frosting you will have to verify that the size of the outdoor section is not over sized in relation to the evaporator coil and that the system is charged to meet the compressors manufactures specifications.
Posted on Jul 21, 2008
Unit alternates cold, warm, cold, warm etc..
in high temps AC units undergo whats called thermal inversion. This is when it blows hot inside and cold outside. I do not believe there is a fix for this. Maybe it is not properly sized for you room? If your unit is too small, it may be working too hard and inverting.
Jul 30, 2014 | Kenmore 75184 Air Conditioner
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
The lines on my air conditioner keep freezing and its not getting cold but the compressor keeps coming on
If your vents inside are blowing normal and your filters are clean, more than likely you are low on refrigerant and it will have to be charged. Also check to make sure the fan motor outside is working when the system is on. Hope this helps!
Jun 19, 2012 | LG Heating & Cooling
2004 chevrolet avalanche A/C not staying cold, after a while goes warm
2004 chevy Avalanches air conditioner blows hot air, can the actuator be forced to keep it blowing cold air instead of hot air all the time.
Jul 20, 2010 | 2004 Chevrolet Avalanche
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Ac BLOWING HOT AIR INSTEAD OF COLD. All of a sudden my AC started blowing hot air instead of cold. It is set on cool.
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Apr 18, 2009 | Hunter 30124 Air Conditioner
Some times AC blows hot/warm air
Not sure which model you have but i would check your indoor and outdoor temperature sensors  and also it could be your overload kickin the compressor off
Jun 11, 2007 | Sanyo STW0923H2 Thru-Wall/Window Air...
Heating & Cooling Logo
252 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
