Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer
How can I increase the water level on my washer. I was also amazed to find that the smell I havein my laundry room is coming from the washer!! Please advise - on increasing the water level.
  • cowgirl1124 Jul 21, 2008
    I am using the right amount of detergent and kind. My clothes are not as clean as my top load whirlpool.
  • cowgirl1124 Jul 23, 2008
    I have done all the above-with no results. Even my cleaning the machine, within 3 days it starts to stink again. So I guess I should routinely during the week clean the washer?? although I'm not washing any clothes?? this is the first time I have to routinely maintain a washer. The water level is to low. I use the correct detergent as well. the clothes do not come clean. I guess I can be proud of my machine & head to the laundry mat!
    Scholar:
  • 50 Answers
Increasing the water is not possible and would not help anyway. The odor is from bacteria. To kill the bacteria run a load without clothes on the HOT wash setting and add a cup of bleach to the soap dispenser. In the future to prevent it from returning use the hottest water allowed by the clothing care tag and use bleach whenever possible. If you don't like to use bleach or hot water you may need to repeat the cleaning once a month. Also make sure you are using a HE detergent. Non HE detergent can suds up and the suds may not rinse out with the water and can create an odor.
Posted on Jul 21, 2008
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
Readout is flashing F35
Pressure switch issue. You will find it under a water level switch.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front loading washer has mold and mildew growing even though I clean it out often. It makes the laundry room smell.
yes they are very good for that... and for the bad news it is almost impossible to get it out.... sorry for the bad news but all of them do it
May 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer, water leaks out onto the floor, when not running.
warter seeping through valve remove power cord. them cut off water at wall remove 3 t20 screws from back of top panel slide panel toward rear to remove. remove hoses and electrical connections from valve remove 1 t15 srcew from back of rear panel to remove valve replace with part # 8181694 for about $50
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
163 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
