Did you ever get the picture fixed. I have the same problem and was wondering if its worth fixingDid you ever get the picture fixed. I have the same problem and was wondering if its worth fixing
You can't post conmments that contain an email address.
Hi, Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs. Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person. Hope these info will help. Thanks.
Hi, I would like to view that short video clip to diagnose possible cause of picture problem and would you please confirm model number of tv that would be written at rear? Thanks.
Hi, When tv shuts down for some reason, does it turn on again itself or you need to press power button to turn it On? Let me know how old is this tv and any other related info that you think might be helpful to diagnose problem. Thanks.
Hi, Do you see same solid black box in all inputs or just in dvd picture? If solid box appears only with dvd picture then its generated by dvd player, check dvd player Menu and turn off any subtitle settings. And if solid black rectangular appears in all inputs of TV like cable etc then check Close Caption feature in TV and turn off CC function. Hope this will solve your TV problem. Thanks.
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
This TV uses small voltage regulators. On each side of the regulators is the input voltage and the regulated output voltage on the other side. There are capacitors used for stabilization on the input and output. Change these capacitors.
