When i insert my computer the cd so as to install new operatin system it responding the ff disk is corrupted
    Problem Solver:
  • 20 Answers
You will need to go into the BIOS and make sure that the CD/DVD drive is the first on the list of BOOT Priorities.
It sounds like its going straight to the HDD, hence it is courrupt?
Posted on Jul 21, 2008
Hp compaq 530usdt windows\system32\conf\system. File missing or corrupt
insert original win installation cd and reboot... when in boot mode make sure you are booting from CD, not from disk, when message asking that you "boot up from cd " appears, just press any key, and folow procedure, but do not install a new copy of windows ! There must be "repair your computer" option on your CD, for Win Xp - it is "recovery console" ! When repairing finishes restart computer and boot from disk (just do not press anything when you see message "boot from CD..." and let windows from HDD configure it self).
Mar 10, 2014 | Computers & Internet
My laptop won't start and says "NLTDR is missing" press control alt delete to restart... why is that?
Windows is corrupt...
Sol = Reload Windows XP
you will need an original WinXP disk....insert the disk in the CD drive and restart...let it boot from the CD (to make changes to boot sequence make changes in BIOS)
once it boots from CD then repair you OS or install a fresh copy of the OS
May 29, 2011 | Computers & Internet
Bought a new laptop and on start up lost power. Now it won't start up Windows - failing to load because the registry file is missing or corrupt
Since you recently bought it, simply return the laptop and get a new one. These kinds of things happen with computers and is no one's fault. It shouldn't be a problem to get a different computer of the same type. If you cannot return it, use your windows recovery disc to solve the problem. I hope this helps and have a nice day!
May 03, 2011 | Acer Computers & Internet
I bought a compaq laptop computer, when i turn it on it says, no bootable disk-- insert bootable disk and press any key.
You either have a failed hard drive or else a virus has corrupted the partition on the hard drive so it isnt found by windows. I am willing to bet that your hard drive had reached the end of its life. If this is the case you can get a new one and have your operating system re-installed by a friend or family member that is comfortable in doing so. Loading the operating system isnt that difficult with the correct CD's. If you have Vista or Windows 7 then most of the drivers will install automatically. If you have XP then that is a bit more involved as you will have to install most of the drivers that are required.
Feb 17, 2011 | HEWLETT-PACKARD Hewlett Packard HP Compaq...
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
The laptop shows windows system 32 configuration file corrupt error how to run laptop?
Windows system 32 file is part of the operating system and when it is corrupted, you cannot boot up your computer. I suggest if you had a systems back files, use it to recover the missing file. Just load the back up disk CD/DVD into the CDROM, boot up your computer and run it to CDROM and option will display and choose the repair.
If don't have the systems back up disk. Only solution is to reinstall or repair your operating system.
For reinstalling and repairing, insert the OS installer CD in your CDROM and boot up your computer and run the repair or reinstallation process. Follow the procedure.
Jan 13, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
On turning on my computer I get the HP screen with three options at the bottom Boot menu Startup menu System recovery When choosing the boot menu or startup menu the computer fails to bring up these...
The hard disk inside the computer had failed and must be replaced.
Since your system had an recovery partition and not a separate recovery disk you must contact HP and order a separate recovery disk. If you have a friend with the exact model of c then you can use its disk, but only if its the EXACT same model.
 This is a very big problem - and at least a basic knowledge of hardware is required to replace the failed hard disk. And some software experience is also needed to reinstall.
Aug 10, 2010 | Computers & Internet
When i turn my computer on i get a message that says, disk boot failure, insert system disk and press enter
Your boot file on your hard drive may have been corrupted. You need to start the computer with your operating system disc in the drive, and hopefully it will be able to repair your operating system. good Luck!
Jul 17, 2010 | Compaq Presario SR1030NX (DW256A#ABA) PC...
How do i install a newer operatin system
Burn all your data on some dvd's , go into the BIOS and change the boot order - put the cd first , insert the install disk for the new OS, reboot and follow the instructions that are going to appear on the screen.
Mar 01, 2010 | Dell OptiPlex GX260 PC Desktop
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
