Question about Microwave Ovens
DISPLAY PANEL is the replacement display panel just the small (which will require soldering in) or both panels (joined by the flat cables) has anyone the part no for the above
  • 100 Answers
Check with www.microwavedisplay.com - you'll need to provide the brand and model number.
Posted on Jul 22, 2008
How do I unlock the control panel of a ge microwave oven?
See the link
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
  1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day. A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
  2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
unlock the control panel of ge microwave Google Search
Nov 05, 2017 | GE Microwave Ovens
Dacor DM02420S Micrwave Display Screen - Can't see anything
can you see any thing like a circuit in that pannel.check for the soldering joints in that pannel.
Oct 12, 2008 | Dacor DCM24 Convection/Microwave Oven
Panel light on Bosch microwave out but works fine. I'm just flying blind
I have had sometmes where bad solder connections on the display crystal stopped the display from working. May be worth a look at the connection on the main board where the display crystal is soldered to the board. If not, new main circuit board $$$$. Sharp uses a conductive rubber pad below the crystal to conduct power to the display. It is possible Bosch did something like that too. If so remove the main board, see how the crystal is connected to the board. Clean the rubber conductive pad or look for bad solder connections.
Sep 30, 2017 | Bosch Microwave Ovens
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
The display is too dim to read. what can I do?
Depends if it was dim when new then not a lot you can do
if it has gone dim , you have 2 options
1 unplug it and put plug in front of oven door,then remove all cabinet screws.locate the display control printed circuit (under display)take photo of wiring with phone to aid reassembly ,unplug and remove printed circuit board screws and board,clean display screen and window ,if was clear then either obtain replacement panel or take panel into radio or electronic repair shop and have them check and replace any poor electrolytic capacitors, this usually cures older ovens ,but if 6 0r 7 years old displays themselves dim and need replacing.ps if good at soldering just note these capacitor values uf and voltage and obtain at maplin and replace all observing polarity when fitting
Jan 11, 2015 | Microwave Ovens
GE JNM 1851 microwave display panel light is out
The GE Answer Center is telling it like it is. Bet it's touted as a customer-friendly "improvement".
Sep 05, 2017 | GE Microwave Ovens
Display panel has lost most of its dots. can't read it
debe ser revisada por un tecnico por que parese ser la targeta de control da?ado por incectos o por cucarachas
Oct 05, 2010 | Sharp R-1750 Microwave Oven
Control locked
Howdy:) Try this:
Microwave - Explanation of the Child Lock Out Feature
Farmerbear at FixYa.com
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
Sep 13, 2010 | General Electric Microwave Oven
SHARP MICROWAVE R-310AW DISPLAY GOING OUT
Remvoe the panel and see if there is any infestataion of cockroaches or insects into the display panel. if so remove and clean the bord properly using some petrol and a brush. make sure you do not damage the display or the board. Now check for any dry solder on the printed board , if bad do a touch up solder on the suspected dry points. check for the filter capacitors of the power supply and the regulators.
Check votage to the mP , solder the crystal and check.
Aug 27, 2010 | Sharp R-316FS Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
