Question about Mitsubishi WS-65313 65" Rear Projection HDTV
Format Change My TV changes from expand to standard format by itself, usually after a couple of minutes.
    Genius:
  • 1,199 Answers
There may be a setting in the menu that you have to turn off to stop this
Posted on Dec 09, 2008
The tv does not show top or bottom of tv. The settings does not have a way to change the screen. Is it even possible?
If I am thinking about what you are talking, then it seems to be a problem with your aspect ratio/format etc. You can usually change it with your cable box and your tv.
Apr 25, 2012 | Emerson Televison & Video
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
My 57731 cycles through formats by itself. It goes from standard to wide expand and back again over and over. It stops after about 30 minutes.
If there are any format buttons on the front of the TV make sure it doesn't appear to be stuck. Also there is a possibility that a button is sticking on the remote for your TV or cable box or satellite
Sep 08, 2010 | Mitsubishi WD-57731 57" Projection HDTV
I am getting black borders top & bottom on some channels and side to side as well on Fox on my Dish Net receiver 322 to analog TV.
Hey there! Becki Barned from Dish Network customer service here. The black borders are usually caused by watching standard definition programming on a high definition television. Try to change the format on your tv. Either by pressing the * button below the 7, or trying a format or display button on the original tv remote. Hope this helps!!!
Aug 21, 2010 | DISH Network 322 DTV Receiver
After Power outage - picture is larger than screen
This TV also should have similar facility like 19" Tv. Try the menu, it may be in different name or classification. I do not suspect circuit fault. If you can access service menu code you can try. Better take assistance from service center. If you access service menu, do not for get to note down the values in each and every step.
Apr 30, 2010 | Philips 19PR19 19" TV
My tv change format size from expand and standard on it own. How can I solve this problem?
My 65" Mitsubishi just started this as well. Any updates? Repair or time to get a new set?
Nov 08, 2009 | Mitsubishi WS-55313 55" Rear Projection...
My 27" Standard TV is showing all channels and movies widescreen
on some remotes there is a button to do this and can only be done using this button-
if you have a sky box or other you can go into services/picture settings and change format here.
if in dout R.T.F.M................lol
Aug 06, 2009 | GE 25GT240 25" TV
The whole picture doesn't fit in the screen.
If u are using a cable box there maybe a format button on that as well. So use it in conjunction with your tv format button to get a picture that fits the screen. Make sure no zoom format is selected
Apr 09, 2009 | Televison & Video
Change format
there is a button on the remote labeled FORMAT it is on the bottom half of the remote. it will change picture size i.e. STRECH STANDARD WIDE WIDE ZOOM etc.
Apr 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Overscan????
Sound like it is in a expanded format. These sets have a couple of mode it can run in one is called 9X16 expand. this makes the pix to big, but you probably need the original remote with the format button on it, luckily these are cheap and be had at www.vancebaldwin.com
Mar 19, 2008 | Philips 30PW8420 TV
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
