Question about Samsung LN-S4051D 40 in. LCD Television
No sound I have the samsung 4053H 40 LCD After switching to HDTV converter boxes we loose sound It's not just with hd channels. typically doesn't happen while xbox games are being played on it. I switched converter boxes and still looses sound. any ideas?
Hi,I have samsung T.V. but nearly 2 OR 3 months we had a problem of no sound (It is an on and off trouble) .can you tell me about this?
Name-Om Prakash Pareek
Address-H-32 shastri nagar,jodhpur
phone -2641100
Posted on Jul 21, 2008
Does sk-26h590d have HD connection
It might have a built-in HDTV tuner or it may require installation of an HD converter box. If you see decimal channels such as 3.1, 29.2, etc. you have an HDTV tuner. If you see channel numbers without decimals such as 3, 29, etc. you will need to install a converter box
Dec 27, 2012 | Westinghouse Electric SK-26H590D 26 in....
Samsung LN-S3251D intermittent sound problem
Try to check the connection from your HD reciever it could be a loose signal from the reciever that why the sounds cut out..
Tell me more.
Thanks
Feb 19, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Some HD channels won't work on new Samsung tv.
Some hd channels can only be viewed by watching thru a cable box. If you are using a cable box check with your cable provider to see what the issue is.
Dec 23, 2009 | Samsung LN52B550 52 in. LCD TV
Comcast Remote Control Code
It sounds like you either have a signal issue or a bad converter box, possibly both
Apr 23, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
HD ready?
It was not a problem. It is just a question. Is it HD ready or not without a converter box or cable?
I will go to a store and ask a tech if you can not answer.
thanks
Jan 14, 2009 | Akai LCT3201TD 32 in. LCD Television
DTV converter box
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
Oct 18, 2008 | Insignia Digital-to-Analog Converter for...
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung LN-S4051D 40 in. LCD Television Logo
114 people viewed this question
Henry  Thomas
Henry Thomas
