Question about HP Photosmart C6180 All-In-One InkJet Printer
Ink system has failed. Error:0xc18a0001 Ink system failure error 0xc18a0001
  • 3,037 Answers
The manual will say to turn it on and off and also to unplug it and hold the ok button while doing so. If this doesn't work, then go to
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1153494&lc=en&cc=us&dlc=en&submit.y=8&submit.x=5&lang=en&cc=us
and upgrade the firmware, you will first have to select your operating system. This should then solve the problem.
If this still doesn't work, then contact hp at www.hp.com/support and click on Contact Us and go to and sign into the chat line for 24/7 tech support assistance where they will most likely run you through the same process once again but if everything they tell you fails, they will then send you a different firmware.exe file that will definitely fix your problem. Let me know if the link works or if you run into any other problems
good luck
Posted on Jul 21, 2008
    President:
  • 2,712 Answers
Can you provide more details, please? Did you try replacing the cartridges, etc?
  • HP Master
  • 19,396 Answers
Did you replace cartridges?
  • Ginko
    Ginko Jul 21, 2008
    To fix this error:
    1 Replace cartridge with original ones, faulty or empty cartridges can cause the problem.
    2 unplug printer power cord for five minutes, see if resetting in this way clears the error.
    3 If it does not clear contact HP support, they will give you a firmware patch that clear the problem. To contact HP support Click here, select your country, select support click on Contact Us and go to and sign into the chat line for 24/7 tech support assistance. They will give you the link for the download.
4 Suggested Answers
SOURCE: Ink System Failure Series C7280 Error 0xc18a0001
Reset the printer. Thanks.
Posted on Jun 14, 2009
pineworks
  • 4041 Answers
SOURCE: hp photosmart c5180 ink system failure
Hi ok then try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
puertobori
  • 7725 Answers
SOURCE: Ink system failure the ink system has failed and
Go to An '0x ...' Error Message Displays on the Front Panel When Printing HP Photosmart C5380 All-in-One Printer - HP Customer Care (United States - English)
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Jan 28, 2011
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
Sharp ar gives me error number h4 how to let it work again
The error H4 stands for the heater roller H3 (Fuser) temperature is low and probably burnt out. You need to call for service.
Jan 08, 2017 | Sharp Office Equipment & Supplies
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
567 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
