Question about Samsung SGH-c225
No power, all buttons flash when connected to ac charger
I don't see voltage on battery, checked voltage on batt conn on cell phone with batt removed and ac charger connected I see 2.7v and 4.1 volts (tests done with no simm card)
Tried to open up and clean, still same. Doesn't start, all buttons flash when connected to ac charger.
Pls help, need to retrieve phone book.
Thanks
  • mcubeu Jul 21, 2008
    Thanks tatonot, it seems that the battery was shot. I connected charger's cable directly to phone batt terminals and got the screen.
    Thanks for guiding me.
    Problem Solver:
  • 12 Answers
If charger voltage is ok then it could be phones charging controler is not working. if phonebook is only thing you need could recharge battery directly from your charger and then save your phone book. cut off charging plug-connector from your charger make two bare wires and then apply red wire to battery "+" and blck to "-". 5min of charging will be enough to copy your data
Posted on Jul 21, 2008
Can a battery charger for a camera, electric shaver, cell phone and cordless tool etc., be pluged into this power inverter without damaging those type of batteries.
It's not the battery that might be damaged. It would be the charger. What the charger does after it is damaged might be when and if a battery could be harmed.
Generally any AC powered device plugged into an inverter will work pretty well as long as the inverter is not putting out too poor of an AC voltage AND you don't exceed the inverter's rating.
Aug 26, 2012 | Electronics - Others
Hp probook 4530 ac connected indicator flashing. will not power up
Either your charger is not providing the perfect voltage or there is a short circuit in your motherboard. Try replacing the charger first. If still the problem persists then you should check the connector. try resoldering it cause loose connection in it also sometimes causes this problem.or you need to change the motherboard finally.
Feb 08, 2012 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
USING PERKO SWITCH HOW DO I POSITION SWITCH USING 120 VOLT AC CHARGER USING 2 MARINE BATTERIES AND WHAT TERMINALS ON BATTERIES DO I HOOK UP ALLIGATOR CHARGING CLIPS? THANK YOU DON
Hi Don!
If you wish to charge one battery at a time, the switch should be set to "off". Charger clips will connected to the batt you wish to charge hot-to-hot and cold-to-cold. If you want to charge both batts at once (not really recommended) switch set to "all".
Hope this helps.
Mar 26, 2011 | Perko Battery Selector Switches Ignition...
Ok i got a hp g60 and its weird cause the battery aint charging .. now wat techiesguru was a great success on getting it to come back on.. how ever i had to also unplug the internal battery as well and do...
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 04, 2010 | HP G60-230US Notebook
Dell insprion laptop not charging the battery, showing IDLE when charger is connected to it, my charger is showing idle even in bios setting what is the problem
remove battery.
connect ac adapter.
make sure ac adapter led is on.
connect ac adapter to laptop.
check if ac adapter led still on after connection laptop.
turn on laptop then check bios if ac adapter is determined.
check bios as well if it is updated. if not then download the latest bios update from dell support site.
after updating bios charge the batt while laptop is not use. check if changes will happen on the number of charge. make sure you check the charge in bios not in windows.
if charge in bios made changes while on windows still says idle and not charging then reinstall the OS.
if all fails no changes in charge % batt then have the batt replaced.
Oct 24, 2009 | Dell Inspiron 1525 Laptop Jet Black
Compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Sep 14, 2009 | HP Pavilion dv6000z Notebook
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
Charging problem!!! PLEASE READ!
as i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
Feb 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Samsung SGH-c225 Logo
178 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
