I have a Funai LCD tv Model no B2706. The fault is when it's switched on the screen lights up for a split secound then it's blank. Any ideas Please? Thankyou!
  • 3,037 Answers
Does the standby light change colors at this time. It sounds like it may be going into a protection mode from possible overloading in the power supply.
Posted on Jul 21, 2008
  • 2,326 Answers
It's more likely a failure with the power supply or in some cases the back light inverter assembly could be defective. If any of the boards mentioned fail, the repair might not be a DIY so you should have a service tech to do the work.
If your LCD is less then a year old, contact the manufacturers to have repair under warranty.
  • 19,396 Answers
Well , there can be many causes for this, do you get any led flashing after it turns off?
Need help with Telefunken led tv TLEDD-32Fhdb,only blank screen, with green light on
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 21, 2017 | Televison & Video
I have and LF50 flat screen with a 4" wide black line going from top to bottom down the right hand side. How do I get rid of it?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Oct 11, 2016 | Funai Televison & Video
How can I fix volume control
How do I stabilize volume on a television? : hometheater
https://www.reddit.com/.../how_do_i_stabilize_volume_on_a_tele...
RedditAug 31, 2014 - We have a Samsung Smart TV - 52". My mom is a hardcore movie watcher, and I have very sensitive hearing. It's a constant battle because I'm ...Missing: lc320slx
Funai Emerson LE220EM3 Owner's Manual - ManualsLib
www.manualslib.com > ... > LCD TV > Emerson LE220EM3
Emerson LE220EM3 LCD TV pdf manual download. ... LCD TV FUNAI LC320SLXService Manual ... Model # Screw dimension •. ... Tv, Switching On Your Tv And Putting It In Standby Mode, Adjusting Volume, Switching Channels ... Clock setting tostabilize the PC screen and Phase Canadian French rating, then press OK.
Nov 26, 2015 | Sylvania Televison & Video
My standby light blinks three times but tv never comes on
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/.If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 22, 2013 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Emerson LCD TV won't stay on
http://electro-medical.blogspot.com/
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Apr 02, 2017 | Televison & Video
I would like my sky remote control rev8 to operate my funai tv lcd -b2706 but i just cannot find the right code
Try this worked on mine
Press tv on sky remote, cover the lens with your hand. Then press select and the red key together until you see the led flash twice, then type in 678 on the remote
Oct 30, 2008 | Televison & Video
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
I have a Toshiba 42WLT66 LCD TV approx 18mths old that has suddenly started to lose its picture. Sometimes the screen will switch to coloured lines then fade to a blank sreen, other times it switches...
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 01, 2017 | Toshiba Televison & Video
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
