Computer keeps saying couldnt find ntldr - Computers & Internet
  • 94 Answers
Not enough information.
What computer? What are you trying to do when the error is received?
Posted on Jul 21, 2008
I keep getting a message saying ntldr is missing cant start comp
ntldr is a system file that are using to load your windows. One solution is to use other third party software, my friend used before a SPOTMAO to repair the ntldr and systerm 32 error. Or try to copy a NTLDR file from other computer which is running the same your windows, Just make your drive slave to a computer, then locate the NTLDR from the C:\ then copy it to your drive. Hope it helps thanks.
Sep 21, 2011 | Dell Inspiron 1720 (dncwma1_1) Intel Core...
My computer keeps saying after i done a system recovery that the ntldr is compressed and i cant go anyfarther it keeps say restart
need to reinstall windows.............
could connect drive to other pc or lappy then try coppying ntldr to system.,...........
cheers
Mar 22, 2011 | Computers & Internet
My computer keep saying "NTLDR is missing", How to fix it? How to repair windows?
NTLDR file is needed to start a computer. So in such situation you need to repair windows. To do so:
1. Insert the cd into the drive.
2. Restart computer, it will show "boot from CD........." on the screen. Just press enter key to boot it from CD.
3. And then repair it.
4. Restart it once again to complete the process.
Sep 01, 2010 | Microsoft Computers & Internet
Ntldr missing, trigem dreambook, windows2000 P3 600Mhz
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the rootdirectory of the primary hard disk drive. For example, C:NTLDR andC:NTDETECT.COM should be the locations of these files on manycomputers.
  • Please keep in mind thatthese files are hidden system files, if you need additional help withviewing hidden files in Windows please see document CH000516.
Oncethese files have been copied to a floppy diskette reboot the computerand copy the NTLDR and NTDETECT.COM files to the root directory of theprimary hard disk drive. Below is an example of what commonly should beperformed from the A:> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Jan 13, 2010 | Microsoft Computers & Internet
How can I decompress the NTLDR on my computer? My computer just shut off and when I turned it back on the screen said ....NTLDR is compressed. Press Ctrl + Alt + Del to restart. I have done that and it...
It sounds like the Operating System start up files are damaged. If NTLDR is corrupted then you will need to run the OS installation disc and try to repair the Windows installation. If the repair does not work you may need to re-install the operating system using the installation disc that came with your computer.
Oct 29, 2009 | Computers & Internet
Corupt hard drive 1
First you'll need to acquire an external harddrive enclosure. IDE or SATA depends on your hard drive. Shut the computer down. Remove the hard drive from your computer and place same into the enclosure. You'll need to hook your enclosure with the hard drive hooked up in it to another computer and remove all your data. Place back the hard drive into your computer and now you can do a system restore or a full reformat and OS installation. Respond to me, if you need step by step instructions.
Aug 13, 2009 | E-Machines eMachines Refurbished EMA...
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
NTLDR Missing, Press Ctrl+Alt+Del to restart
What happened is when you changed the drive letters you switched one that should not have been changed.... You need to change it back so the original C: is C:
Because the original NTLDR file was on the C: drive which is the Windows XP Boot Loader and when you swapped it it couldnt find the ntldr on the new C:
From my opinion the only way to switch it back is to reinstall the OS onto the drive you want to be C:
Dec 18, 2008 | Microsoft Windows XP Media Center Edition...
Ntldr is compressed
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Aug 30, 2008 | AMD Compaq Presario SR1030NX Athlon...
Computer crashed and will not restore.
if u tried installing windows from a CD onto the HDD and it still says missing ntldr. seems like a Bad hard-drive.
you can restart by pressing control-alt-delete.
then, try booting from windows CD and repairing the windows installation. if it gives u file copy errors.then, it is a HDD failure. get a new HDD.
Mar 30, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
