Question about Gateway 550GR PC Desktop
Looping reboot My Gateway computer will start to enter windows xp and then automatically reboot and keep doing so.
  • Joestile Dec 28, 2008
    I have the same problem with my 550GR that boots with Window XP then keeps rebooting and rebooting.  I used the Restore disk, wiped out everything and started over.  But I have the same problem.  Could this be a virus in a hidden sector or is my hard drive failing?  Does anyone out there know?
    Sergeant:
    Champion:
  • 327 Answers
Welcome to fixya
the easiest way i can tell you to fix it is try to reboot the computer with the windows cd
if this does not work plz let us know thz
have a good day
Posted on Jul 21, 2008
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Making a bench machine on the tyan dual core pentium III mother board
Rebooting is tipical of Windows XP when there is an important error. Most of the time this error is coming from the hardware.
There is a way to know the error code that make Windows XP mad, but you have to eliminate the automatic restart option.
With your mouse right click on My Computer, select properties, select advanced and you should see something similar:
deselect Automatically restart.
At this point next time you will have the error instead of rebooting you will see a blue screen with some message at the top and some code at the bottom, please write them down and post them here.
In case you cannot even enter in Windows XP because is keeping rebooting too fast, try to do the above steps in Safe mode.
To enter in Windows in Safe mode you have to press F8 as soon as you boot and before you see the windows logo on you screen, then select safe mode and repeat the steps above.
Last but not least, please send me the exact type of motherboard, processor and memory that you are using.
Oct 30, 2007 | Tyan Trinity 450 (S2507S) Motherboard
Tip
Disable Automatic Reboot after Windows Update
Have you seen the message
"Automatic Updates
Updating your computer is almost complete. You must restart your computer for the updates to take effect.
Do you want to restart your computer now?"
Automatic Windows updates are very good for computer security. However, when these Windows updates are downloaded and installed on your computer, if the updates require a reboot of your computer, Windows keeps prompting you to reboot your computer.
Now, Windows XP Pro users can disable automatic reboot of the computer after a Windows Update. In order to do that, follow these steps
Disable Automatic Reboot after Windows Update for Windows XP Pro usersWith this setting you will be able to specify that after a scheduled Windows update, Automatic updates will wait for the computer to be restarted by any user who is logged on, instead of causing the computer to restart automatically. If this setting is not enabled or not configured, your computer will prompt you every 5 minutes to restart the computer to complete the installation.
1. Press <Windows Key> + R which will launch the Run command. Type gpedit.msc and press Enter
2. Group Policy Editor will now be launched
3. On the left hand pane, under Local Computer Policy, click on the (+) sign next to Computer Configuration
4. Click on the (+) sign next to Administrative Templates. Then click on (+) next to Windows Components and then click on Windows Update
5. Double click on No auto-restart for scheduled Automatic Updates installations. A settings window will now open. In there, select Enabled and then press OK
6. Close the Group Policy Editor
Disable Automatic Reboot after Windows Update for Windows XP Home usersThe settings are a bit different for Windows XP Home users because there is no group policy configuration for Windows XP Home.
1. Press <Windows Key> + R and type in regedit. Press Enter
2. Navigate to
HKEY_LOCAL_MACHINE SoftwarePolicies MicrosoftWindows WindowsUpdateAU
3. Change the "NoAutoRebootWithLoggedOnUsers" DWord value to 1 to Disallow auto reboot.
4. Press OK
if this tip really help u pls vote ,...........shailendra
on Oct 03, 2010 | Computers & Internet
Hp nx6110, stays in a boot-up loop
Hi, If you are sure that it's not overheating, then it could be the hard drive.
A boot up loop is an indication that the boot up sector on the hard drive is corrupt and broken. The hard drive tries to find this boot sector to boot up your computer but it can't. It keeps trying to find it again and again and again and keeps looping. Hank
Jul 23, 2010 | HP Compaq Motherboard
I've been building computers since 1992. Never saw this. My EVGA MB is in a BIOS loop. Boot .. beep .. EVGA Splash ... -Reboot automatically- Beep ... EVGA Spash ... -Reboot automatically. It's like a...
Turn the computer off.
Hold DOWN the "any" key.
Turn the computer on.
When you see "keyboard error. Press Fxx to enter BIOS SETUP", RELEASE the "any" key, and press the 'Fxx' key.
While in setup, change the boot-order to "floppy-first".
Then, everytime that you boot, your motherboard will "grind" the 3.5-inch disk, looking for a boot-sector.
If it DOES "grind", then BIOS-loading has completed, and there's something wrong with the boot-sector on either the CD-ROM or the disk-drive, i.e., Windows "crashes" during startup, and reboots itself.
Or, press F8 when you think that your computer is booting from the disk-drive, to enter the "Windows boot menu". Try "Boot In Safe Mode".
Feb 03, 2010 | Evga MB 115-K8-NF33-AX NF3-250 754...
Having a problem with my gateway comp. using
  1. Boot to your XP CD, enter Recovery Console and run the command CHKDSK /R and see if that resolves
  2. Run diagnostics on the HDD, it may be failing, replace HDD if diags fail
  3. In-Place (Repair) reinstall of WIndows http://windows.microsoft.com/en-us/windows/help/install-reinstall-uninstall
Jan 25, 2010 | Microsoft Windows XP Media Center Edition...
How to open the key ports for windows XP professional
You have probably set up your system to use DHCP - that is non-static IPs.
Right Click on your connection, go to properties, click IPv4, properties again
if it says get settings automatically then you are using dynamic IP addressing DHCP... this can cause problems,
To set up your Static IP on your computer
you will need your routers default gateway
you get that by typing ipconfig at the command prompt... found under Start menu ->Accessories, Command Prompt
Type in IPconfig
look for default gateway - write it down.
Go to your ISPs web site and see if you can find their DNS server IP addresses -or search under google - as a last resort use these
62.24.199.13
62.24.199.23
All DNS servers are public and free to use.
Then enter your Static IP which is derived from your default gateway. So if your default gateway is 192.168.1.1 then your IP can be anything between
192.168.1.2 and 92.168.1.254
Subnet = 255.255.255.0
Enter your default gateway
Enter your DNS server IPs and you should be good to go....
Remember if it all goes horribly wrong for some reason (It shouldn't) then just return and reset everything to get settings to automatic and all will return unrtil another solution is discovered.
Oct 06, 2009 | Microsoft Windows XP Professional
Internet explorer will not allow to go to secure settings
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows
Solutions
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration.(this can be done by tapping the F8 key while booting and selecting last known good configuration)
  1. Insert the Microsoft Windows XP CD into the computer. Note: If you have a system recovery CD or restore CD (not a Microsoft CD) these steps will likely not work for your computer.
  2. Reboot the computer with the CD and press any key when prompted to press any key to boot from the CD.
  3. Once in the Microsoft Setup menu press R to open the recovery console.
  4. Select the operating system you wish to use; if you only have Windows XP on the computer you will only have one prompt.
  5. Once prompted for the password enter the Admin password and press enter.
  6. Once at the command prompt type bootcfg /rebuild to start the rebuild process.
  7. The rebuild process will step you through a number of steps depending upon how many operating systems you have on the computer and how the computer is setup. Below is a listing of the common steps you are likely going to encounter.
    * Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
    * Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter "Microsoft Windows XP Home edition".
    * Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
  8. Once you have completed all the available options in the rebuild and are back at the prompt type exit to reboot the computer.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
Jun 04, 2009 | Gateway GT5656 Desktop PC
Rebooting Loop
try starting it with the operating system disk in it, and do a reinstall, might help, or clear it up....if it fails, could be your power supply going out....hope it helps...shia
May 02, 2009 | Sony VAIO VGC-RB43 PC Desktop
My windows xp keep rebooting after shutdown
You should be able to change this setting in the PC bios menu. Windows XP should interact with this and change it automatically, but it occasionally doesn't. If you have trouble finding the appropriate menu and changing it, please post back with details of your PC (ideally motherboard make and model) and we can hopefully talk you through it. When the computer starts up, there should be a screen before the windows XP screen which says something like "press f8 to enter BIOS setup", but all machines are a little different. If you can get into the BIOS setup, only change things which you are sure you know what they will do, or you can cause all sorts of problems. Hope this helps, post back with system details if you need more :)
Jul 02, 2007 | Microsoft Windows XP Professional With...
Gateway 550GR PC Desktop Logo
164 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
