Question about OKI C5500n Printer
Will not print.
Can not print via usb port.
Mac laptom does not give oki as an obtion on the print using field they have alot of companies on there but not oki the computer is reading the c5500
Posted on Oct 30, 2008
Cannot print says printer offline
try different usb port, try different usb device to see if port is working try different cable.
Apr 16, 2014 | Apple iMac Blueberry Mac Desktop
Printer installation on notebook and PDA
the problem may be that the driver is pointing the printer to print via the serial port, so you will have to go to the printers and faxes folder and see if your printer is listed, if so right click and select properties, then in the next window, click on the 'Ports' tab and you will have to click configure port to change it to usb.
May 29, 2007 | SiPix Pocket Printer Thermal
How to use toshiba e232 printer without ****
Without a print enabler (this allows you print through the network), the only option is print through the USB port, Want to be able to print by anyone in the network, share printer with a host PC via USB, or use a net print server (via USB).
Oct 21, 2011 | Toshiba Office Equipment & Supplies
Can i connect usb port to printer port for network printing
No. The USB port on your cable modem is intended to be used only for connecting a pc to the network. Sorry for the bad news.
For network printing you can use a dedicated print server like Edimax ps-1206u, a great device that make even old printers to get on the network via USB and Ethernet ports it haves
Aug 07, 2011 | Linksys CM100 Cable Modem
Canon ir2016 TROUBLESHOOT printer problem
Hi mate,
Prior to the issue you facing currently seem like ,
1)have u put the printer driver as default.
2)have u point to the correct printer port at the driver.
3)at the driver advance setting ;get the device status then reboot the machine .
GOOD LUCK MATE......Kindly RATE ME!!! Thanks YOU.
Sep 26, 2009 | Canon ImageRunner 2016 Copier
Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Apr 20, 2009 | Canon imageRUNNER 5000 Copier
I NEED TO KNOW HOW TO ACCESS MY USB PORT CONNECTED TO MY PRIN
You save your data to to the USB 'stick' via your PC's USB port, not the port on the printer. This port is simply for printing information already contained on the stick.
Mar 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
PRINTER WONT PRINT
If you has been connected your printer via USB be sure that the printer port is "USB Virtual Port" and NOT Lpt1
Oct 07, 2008 | HP LaserJet 4000tn Printer
Printing to a Canon MX310 through a print server
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Nov 11, 2007 | Canon PIXMA MX310 All-In-One Printer
OKI C5500n Printer Logo
144 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
