I have a Magnavox 15MF400T/37 LCD TV operating with a cabel connection. As of yesterday it has no functions but when I turn it on I get a message that says Attention No Signal. I have checked the cable connection and it is good. I can't get the TV to give me a menu and none of the troubleshooting hints cover this message. I can change channels but after a few seconds, the TV automatically goes to standby mode. when I turn it on again I get the same No Signal message and the screen is black.
  • 1 more comment
  • je25williams Jul 21, 2008
    I have tried turning the TV on through a DVD player. That does not work either. It is not the cable connection. I have checked that with another TV.
    So if the tuner has failed, what does that mean? Does the TV require repair or is it gone?
    I have done all that you suggest with the disconnect, cable checks, etc. Still No Signal.
  • 19,396 Answers
Do the following to test your tv:
Disconnect all devices, including cable, DVD , tuner etc.
Unplug (turning off is not enough ) poer cable from tv for 20 or 30 minutes.
Get a portable aerial, old coaxial cable.
Start tv with only portable aerial and power cable plugged.
If it stays on connect back cable and dvd.
Cable cable carries power along with the signal, cable and sctellite devices sometimes cause similar problems.
Posted on Jul 21, 2008
  • 2,296 Answers
In the event that you have a defective tuner, the part itself might not be available but the whole assembly where the tuner is mounted could be available from philips.
If your TV is less then a year old, still under warranty by the manufacturers.
  • Jaime Hernandez Jul 21, 2008
    The cost for the repair might not be economical if the entire assembly needs to be replace.
  • 2,124 Answers
If you have verified that there is a good signal on the cable (try the cable on another TV) then it looks like there is a problem with the tuner. Something in the tuner has failed and the set is detecting a loss of signal.
- Jim
  • SHARCNET-USA
    SHARCNET-USA Jul 21, 2008
    A defective tuner can be repaired/replaced but it will require a qualified technician to do it. The technician will also have to have access to the replacement parts and a schematic/Interconnect. You will need to take it to a service center and obtain an estimate. You will then be able to determine whether or not it is worth fixing or buying a new unit. If it is under warranrty, your repair will be covered.
    - Jim
  • SHARCNET-USA
    Also, if this is a problem that just happened out of the blue, without the user moving the set or bumping the RF input connector, I would still say you have a tuner issue.
    A bad RF input connector would be loose. This is more critical if the jack is soldered directly to the main PCB rather than using a cable from the jack to the main PCB.
    The user didn't mention if the set had been moved or jarred, so I am assuming the problem just happened without any external influence. If that's the case, then I would try doing a power reset. If that doesn't work, then have the tuner looked it.
    - Jim
    President:
  • 2,712 Answers
Some of the newer TV's dont turn on if there is no input signal. Try a DVD player and see if that works. If it does, then the issue is most likely with the cable jack on the TV, which may need to be replaced..
I moved and lost the "antenna" for my Maganovox 15" LCD TV, serial no 15MF400T/37. Where can I buy another one?
I would suggest you see the website, MCM Electronics.com or Matelectronics.com. They will have what you are looking for. Thanks for asking and show all hands of support!
Jul 10, 2011 | Philips Magnavox 15MF400T 15 in. LCD...
I NEED A POWER SUPPLY AND CORD FOR A MAGNAVOX 15' LCD TV MODEL NUMBER 15MF400T/37 POWER RATING 12V 3.5A
Either you can get this universal type available inthe market in any electronic spares store or it is easy too make one by yourself if you are familiar with electroncis.
All you need is a mains transformer with secondary voltage at 12 volt and 4 amps capacity, use a bridge rectifier , good storage capacitor of about 4700mfd/25 volts and if possible use a 12 V regulator so that the power is smooth, regulated and protected..
Sep 24, 2010 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 37MF331D/37 keep asking for software upgrade
Your set either has a bad SSB (small signal board) or needs a software upgrade. Try the upgrade first by going to http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&grp=TV_GR&session=20090830171041_4.131.87.247&ctn=37MF331D/37&mid=Link_Software&hlt=Link_Software
Download the latest software release for your set then follow install instructions that are contained in the user manual for your set.
Jul 22, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 15MF400T/37 No Audio
Get a set of multi media speakers and connect them through the microphone plug in the back. I have mine set up this way and the sound is awesome. I purchased the Creative T-10. Can be found on ebay for around $15 + shipping.
Jan 27, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
IR reciever in my Magnavox 15MF400T/37 does not respond to the remote.
You basically have to take the tv apart backward to get to the front. Start with the back panel unscrew all the screws. Then you will see the internals. IR sensor should be botton left side if you looking down on it.
Sep 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Looking for tv code
Magnavox 0054, 0030, 0706, 0020, 0187,
0179, 0024, 0096
May 23, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Cable for my manavox 15mf400t/37
The tuner and or the IF sections in the TV are going defective, or there is a power supply distribution fault that is effecting the TV's front end. One or both modules, or a board may need to be changed.
Take the set to the Philips authorized service to verfiy and fault and have an estimate.
Jerry G.
Apr 25, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Need Help
check the cable connecting to the System unit!, it could have loosen up!
tighten it
Feb 15, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
