While starting computer ,after displaying all the icons again its restarting
    Genius:
  • 2,785 Answers
Plz check the ram and power supply
Posted on Jul 21, 2008
Why can i open any of my icons on my laptop all my icons says ie
I would right-click & delete each icon and get Windows 7 build a new copy, You will need to delete the IconCache.db file and restart your computer in order to allow Windows to create a new one.
To rebuild your icon cache:
  1. Close all programs
  2. Click Start, then type CMD into the Search programs and files window.
  3. Right click on the CMD program that is displayed above and select Run as administrator.
  4. Navigate to C:\Users\<your user name>\AppData\Local. This can be accomplished with the command:CD /d %userprofile%\AppData\Local <enter>
  5. Delete the IconCache.db file that resides there. e.g. DEL IconCache.db /ah<enter>
  6. Close this command window and restart the computer.
If your icons do no immediately return after the restart, simply restart it agin. I've never had to restart more than once myself, but I've heard of others having to restart two or three times. This is most likely due to having programs and/or Explorer processes running before the first restart, e.g. not following step 1.
May 26, 2014 | HEWLETT-PACKARD HP PAVILION DV63230US...
How do you disable the on board videocard on a hp p6130f?
Turn on the computer. Press the left "Ctrl" key. When the start-up menu appears, select "Safe Mode" and press "Enter." Once the computer enters safe mode, click the Windows "Start" button. Go to "Settings" and open "Control Panel."
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
Aug 26, 2012 | HP Computers & Internet
When i start computer there is no display on the monitor. when i restart computer many times(4 to 5 times) then display is shown . i also changed my RAM
How about try changing your display setting, go to control panel. Double click display icon, click settings, click advance and monitor. From your monitor settings change screen refresh rate to 60 Hertz and click ok and ok. Try to restart your computer and observe.
Sep 22, 2010 | Intel Pentium Dual-core Processor E5200...
My computer displays the normal windows with its desktop icons but automatically shuts down. there's a dialog box that appears but i cant read the content because it disappears in a flash, what do you...
when your desktop loads, click on start menu, run, and wright: cmd
then wright: shutdown -a (in the command promp)
and hitt enter.
the dialog should disappear, restart the pc and check if it comes again that u need to make the same prosses again plus, going to msconfig (righting it in run), and then to the bookmark saying start up and uncheck any suspisious programe, locate its files,delete them,apply and restart again.
May 12, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
I just changed my ink cartridges. The test page will print, but the computer page I'm trying to print...won't. In the bottem righthand corner the printer icon keeps blinking along with a left facing...
hi,
First of all would like to help you so that you can cancel your print job.
On the bottom righthand corner where the prinetr icon blinks simply right-click it and select "cancel," after which the print job status commences to display "deleting..."
So you shoud not be worried about loosing your receipt as you can print it again.
Also
  1. I would like you to unplug the USB wire connected from your computer, turning the device off and then connecting everything from scratch. You can also restart the computer.
  2. Then once the computer is on please click on START and go to RUN and type in services.msc and then on the right side of the page find print spool and right click, then choose restart.
And then try for fresh prints.
Please let me know if the above information helps.
Feb 09, 2010 | Office Equipment & Supplies
Our Hp zd8000 starts up, gets the password, some of the icons show up, then the screen gets blue with some other colors in bars a message comes up saying could not recover from a hardware deadlock, using...
Try restarting into safe mode and using another computer (if one is available) to download Display Drivers for your laptop. These drivers should be available from the HP website free of charge. Copy these drivers to the CD or floppy (depending on which your laptop uses) and if you could boot up in safe mode, install the new drivers and restart the computer. To restart your computer in safe mode, the computer should say a F key (F1-F12) to press during the post to enter safe mode, or you could hold the power button down while windows is first booting to interrupt the boot, and the next time you power on the computer it should ask you if you want to start up in safe mode 'because Windows could not start normally'. If this does not work please respond again! Thank you.
Dec 02, 2009 | HP Computers & Internet
I upgraded winxp sp2 to winxp sp3 and the power meter cannot measure the battery, says on A/C power throughout.
1. Run GPedit.msc to start Local Group Policy Editor.
2. Expand the tree to go to User Configuration -> Administrative Templates -> Start Menu and Taskbar.
3. Change set the state value to Disable or Not Configured for the following group policy to enable showing or displaying of the icon in the notification area.
Power (battery) Icon: Remove the battery meter
4. Close the Local Group Policy Editor.
5. Restart Explorer, Log off and log on again, or restart computer to make the change effective.
Nov 25, 2009 | Dell Vostro 1510 Laptop
Troubleshooting IBM ThinkPad A31 monitor problem
The system is having problems with the graphics drivers, heres how to tell!!! when you first turn the machine on display is clear until it gets to windows. To resolve the problem is quite easy, just reboot into safe mode and un-install the graphics drivers, then reboot. When the system restarts is should re-install the graphics drivers automaticaly for you, job done :)
keep me informed please
regards
Nov 24, 2008 | Computers & Internet
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
Wrong icon displays in the my computer
There are two ways to create a drive-specific icon. The first step for both is to determine the full pathname of the file containing the icon you want, as well as the index of the icon within that file. To view the icons contained in an EXE or DLL file, right-click any shortcut that links to a file (as opposed to a system shortcut like My Computer) and choose Properties. On the Shortcut tab of the resulting dialog, click the Change Icon button. Click Browse and select the file whose icons you want to peruse. When you find the one you want, count off the icons to determine the correct index. Start in the top left corner with zero and count down each column, then to the right. For example, icon 12 in C:\ Windows\System32\Shell32.dll is a picture of a memory chip. Make a note of the full pathname of the file and the icon index, then click Cancel, and Cancel again—you don't actually want to change that shortcut's icon. The Microsoft Windows files moricons.dll and progman.exe, both found in C:\Windows\System32, also contain numerous icons.
One technique for assigning a drive-specific icon uses a file named Autorun.inf in the root directory of that drive. Launch Notepad and enter [autorun] on the first line. Enter ICON= on the second line, followed by the full pathname of the icon-holding file, a comma, and the icon index. It might look like this:
[autorun]
ICON=C:\WINDOWS\SYSTEM\SHELL32.DLL,12
Save the file as "C:\autorun.inf" (you need the quotes to prevent Notepad from appending the .txt extension). Now restart the computer. When you open Windows Explorer, the drive should display its new icon.
The other technique involves editing the Registry. Launch RegEdit from the Start menu's Run dialog and navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\
CurrenTVersion\Explorer.
If a subkey named driveicons is present, open it; if not, right-click in the right-hand pane, select New | Key and name the key driveicons. Under the driveicons key, find or create a subkey named C (or the letter of the drive whose icon you want to change). And under this C key find or create a subkey named DefaultIcon. Double-click the (Default) entry in the right-hand pane and set its value to the full pathname of the icon-holding file, a comma, and the icon index. Again you'll need to restart Windows.
Feb 15, 2008 | Compaq NX6110 TFT XGA Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
