Question about IBM Wheelwriter 30 Typewriter
My typewriter is not making impression
I changed ribbon because I thought it had run out...but the new ribbon is now working either...
  • eliz231 Jul 21, 2008
    I am having the same problem with my wheelwriter 3. I have checked the ribbon and the gear that you mentioned and all checks out good. The print hammer is not moving when I type. So it is not hitting the print wheel so no print...right? What can I do about it? I does feel like I just must have touched something disabling this process. Thanks for you help, Betty
    Sergeant:
  • 329 Answers
Wheelriters have ribbon drive motors that go bad, take ribbon off and watch as you type is the ribbon drive gear is going around, if not chance you have a bad motor....
Posted on Jul 21, 2008
My typewritter wont impress even on hardest impression setting. I think the Ribbon might not be turning eventhough it looks like it is.
If it sounds like it is hitting the paper puy in a multi part form if the copy is OK then you have a ribbon problem, put in a new ribbon.
If there is no print on copy be sure the print wheel is properly latched in place.
DickyO
Aug 03, 2015 | Nakajima AE-740 Typewriter
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a
Try typing on a mulipart form. If it types on the copies and not the orinonal the ribbon is the problem. If it dosen't type on the copies then the plastic cap on the print solenoid is broken.
We sell the cap with installation instructions for 20.00 includes shipping.
DickyO
216-241-0027
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
Brother EM430 white ribbon broken
do you see any impression of letters on the paper when you type? if you do the ribbon not lifting or not driving. If you do not see an impression the print hammer is not firing. try to lub it with wd40 or light Wait oil. some brother typ's have a rubber bumper under the print hammer that deteriorate & need to be replaced
Oct 24, 2008 | Brother EM-430 Typewriter
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
AE-710
First see if the ribbon is spacing a full space for each letter pressed if not you may be in the over strike ribbon mode, to get out of the mode press code and comma, period or slash i'm not sure which one So try them all.
If that dosen't help check to be sure the correction tape is not getting in the way, remove the corr. tape and try it.
Next remove the ribbon and release the hammer as if you were changing the P/W and see if the plunger in the solenoid is free, if not try a drop or two of WD40 on it.
DickyO
Sep 15, 2008 | Nakajima AE-710 Typewriter
My IBM wheelwriter typewriter will not type..
Chances are that the plastic cap on the print solenoid is cracked.
They are available from us for 15.00 but a little tricky to install.
DickyO
Jul 21, 2008 | IBM Wheelwriter 30 Typewriter
Nakajima AE710 typewriter
The forms obviously have a glossy surface, a fabric or multi strike ribbon will work. There is a impression control oh the l. side of the keyboard and also a bold feature, try max impression and bold.
DickyO
Mar 27, 2008 | Nakajima AE-740 Typewriter
IBM Wheelwriter 30 Typewriter Logo
75 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
